Shouldn't worry to much till you've tried it in the water.
I have a Graupner motor in my coaster which on dry land makes heads turn,in the water lovely and quiet.
Hi tight-lines, have you tried the hull in the bath/water?
no ive not been able to yet,bcos ive been to put off by the noise,,knowing even if it helped in water,,it would have to be holy water to total remove the problem noise
i think i know what it is,,are you ready bcos i dont think you will belive me,,and i promise this has took alot of messing to get to this conclusion?
its the motors,yep thats what i think,,its the speed 500e,
i think i might have a bad batch,seriously,,
i done all kinds of experiments,,
but if a hinged couplin cant spin on a flat work top,conected only with the grub screw at one end,,which is the motor end,,,and the other end is left to spin around the inner shaft im holding,,tight and level,,,
it must be the motor,,i also conected just the brass couplin insert on to the motor ,,tight to the motor,,and turned it by hand ,and it was tight ,then loose ,then tight etc etc,,
as if the spindle is a millionth out of line,,,
so when running the motor on its own,you cant tell,so at that stage you would think all is good
but as soon as anything is conected,,its vibration hell !,,
at time of conecting things it can sometimes be made to go away ,moving angle of prop etc,but it could not be posible to fit it to such extremes,,bcos where ever it is held,,it soon finds its vibration in the body of the motor again and amplifies it,,
also it could be that i dont have the natural skills to pull this off,,,,but i am usually good at making things
