Linked Events
  • Kirklees Model Boat Club: May 23, 2010
Author Topic: Steam Boat Convention  (Read 16374 times)
Bunkerbarge
Re: Steam Boat Convention
« Reply #25 on: February 16, 2010, 07:47:09 pm »
In order to help us get the Steam Convention off the ground and to enable as many modellers to join in as possible the Kirklees Club has put together the guidelines as per below.  As you can see the event will be run under Southern Federation of Model Engineering Societies rules which will allow a significant percentage of models to enter that fall below the 3 bar-litre limit and therefore do not have a current pressure test certificate, however proof of the original manufacture will be required.  It is currently hoped that on the day Steam Test Certificates will be available so as long as the models meet the requirements as per below they will be able to steam.
We would very much like to extend the invitation to join in to all steam enthusiasts around the country however we would appreciate it if anyone intending on bringing a model that they wish to steam that they send a PM to myself so that we can get a feel for what numbers we need to cater for.
If anyone wishes to have thier models Steam Tested and Certified on the day then I would very much appreciate having as much information up front as possible to enable the process to be quick and efficient so please forward all details via PM to myself.  I am currently anticipating conducting Steam Tests between 10.00 am and midday and there will be no charge for the test and certificate.
Required information will be the following:
Plant make and type
Boiler Capacity
Working Pressure
Serial number of the boiler
Owners Name
It should be remembered however that a Pressure Test Certificate, as opposed to a Steam Test Certificate will be required at any subsequent Model Power Boat Association meeting anyone might wish to attend elsewhere in the country.
Please note:
1) Any model that is not supported by current, dated certification including a means of linking the certificate to it's respective boiler as required below will not be allowed to steam on the day.
2) Any model that is not fitted with a pressure gauge will not be allowed to steam unless as stated in the small boiler section of the less than 3.0 bar-litres limit.
Please feel free to ask any questions below, which we will try to answer as soon as possible, and please forward as much information via PM as you can prior to the event to make testing on the day quick and easy.
Kirklees Model Boat Club Steam Model Certification Requirements.
The Kirklees Model Boat Club is a member of The Southern Federation of Model Engineering Societies and as such the following requirements as laid down by the club are based on:
The Examination and Testing of Miniature Steam Boilers (Revised Edition 2008)
distributed by:
Midlands Federation of model Engineering Societies
Northern Association of Model Engineers
The 7 ¼” Gauge Society Ltd.
This book is available through any of the above organisations should clarification or further reading be required.
The 3 bar-litre rule
The regulations state that any boiler below the 3 bar-litre limit are not required to be pressure tested however information will be required by the Kirklees Model Boat Club to substantiate any such exemption such as the capacity and the normal working pressure.  The capacity of the boiler is best determined by completely filling the boiler with water, ensuring that there is no air remaining inside, and then pouring the water out into a graduated vessel.  The capacity of the boiler is this volume of water expressed in litres.  The normal working pressure is the pressure at which the boiler would normally be operating at so for a boiler with a means of controlling the burner flame this is the pressure at which the flame turns down.  For a boiler with no means of controlling the burner this pressure is the pressure at which the safety valve lifts.  Pressure is to be quoted in bar and the working pressure must be marked on the boiler pressure gauge in red paint.
The boiler is then classified by multiplying the capacity by the normal working pressure i.e. a boiler with a capacity of 500ml which operates at a pressure of 45 psi is:
0.5 (Capacity in litres) x 3 (Pressure in bar) = 1.5 bar-litres
The boiler types to be considered in these requirements are as follows:
1) Manufactured boilers below the 3 bar-litre limit
Most model boat boilers fall within this category and therefore do not require a boiler pressure test certificate.  Proof however of the boilers origins will be required to ensure that the boiler was manufactured by a business registered to do so.  Consequently either the original manufacturer’s certification or a subsequent pressure test certificate by a recognised test facility will be required.
Small boilers of the Mamod and Wilesco type fall within this category however they will not be required to be fitted with a pressure gauge as long as they were not originally fitted with one by the manufacturer.  They will still be required to undergo a Steam Test and demonstrate the same requirements outlined below, particularly as rergards operation of the safety valve, unless they are already supported by a valid Steam Test Certificate.
2) Home made boilers below the 3 bar-litre limit
Home made boilers below 3 bar-litres must be supported by the certificates issued during the build process.  This will normally consist of two or three certificates issued by a recognised classification society after examination at agreed stages of the build and culminating with a pressure test of 2 x normal working pressure.
3) Manufactured  boilers above the 3 bar-litre limit
Manufactured boilers above 3 bar-litres will be required to have valid, dated and numbered pressure test certificates.
4) Home made boilers above the 3 bar-litre limit.
Home made boilers above the 3 bar-litre limit must be supported by the certificates issued during the build process.  This will normally consist of two or three certificates issued by a recognised classification society after examination at agreed stages of the build and culminating with a pressure test of 2 x normal working pressure.
5) Steel boilers of any size and type construction
Steel boilers of any size will be required to have valid, dated and numbered certificates of manufacture and pressure test issues by a recognised manufacturer and testing facility.
All certification provided must be clearly identified as being attached to a specific boiler.  Although using identification numbers is the normal  means of doing this any other method that clearly identifies a boiler and links it to it's own specific certificate will be considered at the discretion of the inspector.  Certificates that cannot be linked to a specific boiler will not be considered as valid.
Procedures
In addition to any requirements as stated above all boilers are to either undergo the following process or provide valid, dated and numbered certification to prove that the following have been completed by an alternative recognised means of testing.  A Steam Test Certificate is valid for fourteen months from the test.
1) The model pressure gauge will have to be removed and tested against a hydrostatic test kit, which will use a calibrated and certificated pressure gauge.  A red paint mark must be visible at the normal working pressure point.
2) The pressure gauge will be replaced on the model and the boiler taken up to full pressure.  With the burner operating at full flame the safety valve will be observed in operation, ensuring that with the safety valve lifted the pressure in the boiler does not rise to a point above 10% of the normal working pressure.  During this process the remaining requirements of the Steam Test will be carried out, paying particular attention to the following:
a) There are no excessive leaks in evidence of either steam or water from the boiler or the plant.
b) All operating parts of the plant should be demonstrated as working in a safe manner and all moving parts should be demonstrated as being in good working order.  This includes such items as feed systems, whistles and other auxiliary components.
c) General condition of the plant bearing in mind materials used in construction and insulation and standards of workmanship throughout the plant.
d) There is a readily accessible means of shutting off the flame to the burner which may be a readily accessible valve on a gas fired plant or a means of removing the solid fuel quickly and easily in a solid fuel fired plant.
3) After this process has been completed a certificate will be issued to the modeller for that particular plant in that particular model.  For this to be issued the original manufacturers identification code must be visible.
Facilities are to be made available at Kirklees Model Boat Club to cover the requirements of the Steam Test and calibration of the pressure gauges, which will also be available for such events as the Steam Convention.  Club members will be able to obtain certification throughout the year and visitors to the club will be able to obtain Steam Test Certificates on the day.
Bearing in mind the available facilities, experience and expertise at the club pressure testing of boilers will not be available so any boiler that does not meet the requirements of the 3 bar-litre rule must be supported by pressure test certificates issued by an accredited and recognised organisation.
Bunkerbarge
« Reply #26 on: February 17, 2010, 01:01:23 pm »
Please do not forget to let me know if you would like a steam test doing on your plant.  I hope that this will be available on the day to enable as many models as possible to steam.
« Reply #27 on: February 20, 2010, 11:09:23 am »
So what pressure will the Mamods and Willescos have to "Blow off" at?? and how are you going to test it?? This "Discussion" arose on a past posting and I was called down on the validity of testing the pressure gauge. Seems a MUCH more valid point than insisting on a pressure gauge whose value is ****** all when the boat is in the pond, UNLESS you fit a TV camera to monitor the pressure constantly.
  I know the road to hell is paved with good intention, but it's always a problem when trying to adopt a one rule fits all policy. A pressure gauge might be a good idea when fitted to a toy train, but once the human contact is lost, it's a free runner DESPITE the electronic link.
The long Build
« Reply #28 on: February 20, 2010, 11:18:15 am »
Not Sure I can get there but just in case , I Have a Modean boiler in my Windermere steam launch but NO real proof of manufacture , other than most people probably saying oh thats a Modean, Including Mr Modean at the Boat convention last year . Would that be enough ?.
Larry
Bunkerbarge
« Reply #29 on: February 20, 2010, 01:34:30 pm »
First in answer to Ian's point:
The requirements we put together initially were procedures that followed the guidelines of the regulations to the letter.  Questions were then raised as regards small boilers such as the Mamod and Wilesco variety which, strictly according to the regulations, are recommended to be fitted with a pressure gauge.  I spent a long time discussing the point with the Southern Federation and our insurers who both eventually agreed that these types of boilers do not require a pressure gauge.  As far as I am concerned we fully intend complying with the rules as written because that is what our insurance is based on.  Any deviation from the written rule must be approved by our insurers before we will decide to implement such a change.  In this case they have and we are happy to amend our original requirements accordingly.
As regards testing of these boilers, they will first of all be checked to ensure that they have not been modified from the original manufactuers construction.  As manufactured these boilers have a very high factor of safety built in to them as the working pressure is very low (about 15psi) and the factory proof pressure is very high (about 80psi). The safety valves as fitted are normally pre-set and are not readily adjustable. Additional safety is provided by the fact that the oscillating cylinders act as additional pressure relief valves since they lift off the pivot seats. Under these conditions the boilers are perfectly safe PROVIDED that the safety valves have not been replaced to make the pressure system operate at a higher pressure or the manufacturers burner has not been changed. If this is the case the system is not as manufactured and the appropriate pressure accumulation test with a pressure gauge fitted in the system will be applied.
A steam test will be conducted and the safety valve will be observed to operate.  If this does not happen or if the cylinder is seen as lifting from the port face before the safety valve operates then the boiler will not be considered suitable to use.
As has been stated above boilers fitted with pressure gauges will have the gauges calibrated against a certified gauge before performing the steam test.  This has always been the intention and is in line with Southern Federation advice.
Bunkerbarge
« Reply #30 on: February 20, 2010, 01:46:56 pm »
Then in answer to Larry's question:
I cannot find any information about Modean boilers so if I was to be presented with one I would not know what a factory built one looked like.  If you could provide any information in the shape of manufacturers literature, plans, pictures etc. to help us identify it then we would be in with a chance as we could then at least make an informed decision as to whether it has been modified or not.  If you are unable to provide anything to support the validity of manufacture then we would have to play safe and assume it was not a manufactured boiler and, as such, it would require a pressure test certificate.
Accepting word of mouth would leave us wide open to criticism and we would loose all credibility with our insurers.
HS93 (RIP)
  • I cannot spell , tough
« Reply #31 on: February 20, 2010, 02:16:34 pm »
that test may defeat a lot of UK built engines that we are not allowed to talk about  {-) {-) {-)
Peter {:-{
Bunkerbarge
« Reply #32 on: February 20, 2010, 03:17:28 pm »
While we are on the subject of Modean boilers does any one have any information, pictures, instructions etc..etc.. of these boilers?
The long Build
« Reply #33 on: February 20, 2010, 06:08:25 pm »
Thanks for the info. BB.
I am pretty sure that I actually do have some literature that was passed to me when I aquired the Launch,  I will find it...
Bunkerbarge
« Reply #34 on: February 20, 2010, 07:33:16 pm »
Thanks Larry, if you can find it, scan it and send it to me we can be ahead of the game.  If not PM me and we can sort something out.
« Reply #35 on: February 22, 2010, 11:09:32 am »
  Just re-read this and the item should have read "Safety Valve"
  As an addition, and NOT trying to be pendantic, given the fact that we (In general) state that boilers should NOT be constructed from Brass, how does this sit with the insurance companies in that most of the "Toy" type oscillators (Mamod/Wilesco) have this type of boiler construction?? Also should the AGE of the said boilers be questioned due to the material becoming brittle eventually??
   ONLY thinking of public (And Kirklees Club in these litigeous times) safety Richard.
   Regards  Ian
Bunkerbarge
« Reply #36 on: February 22, 2010, 10:23:44 pm »
I understand what you are saying and as usual I try to tread the fine line between doing what is legally required balanced against the common sense aspects.  In this case the insurers simply require us to comply with the regulations as stated in the "Blue Book" so consequently that's what we intend doing.
However as regards the Mamod and Wilesco types I will be having a very close look at thier construction and condition during the steam test to satisfy myself that it is safe, bearing in mind the concerns regarding brass construction.  I am confident myself however that these boilers, working at 15 psi and constructed well over requirements as regards strength, will show signs of failure as a crack rather than a total failure that you may expect at larger capacities and higher pressures.
I'm sure that if there was ever a possibility of one of these failing completely they would never be allowed to sell them nowadays and my main concern when testing them will be to ensure that no modifications have been made from the original.
HS93 (RIP)
« Reply #37 on: February 22, 2010, 11:54:23 pm »
   Regards  Ian
will you be there sailing Ian ?
« Reply #38 on: February 23, 2010, 09:47:48 am »
No I won't Peter cos my original posting on the other thread pre determined that, BUT, if the questions are asked BEFORE the event, it saves lots of egg and resentment on the day. :-))
  Having said that, I do own a rather good pair of binoculars.
  Regards  Ian
Bunkerbarge
« Reply #39 on: February 23, 2010, 11:06:09 am »
Which is precisely why we are trying to get as many questions out in the open before the event so we can identify any issues and then maybe even resolve some of them.
What was the issue that pre determined that you won't be sailing?
  Regards  Ian
« Reply #40 on: February 23, 2010, 11:46:01 am »
Because as I mentioned on this thread and wrote on the other, a Safety Valve is the deciding factor, and no matter how many pressure gauges you have, at whatever accuracy, when the boat leaves the edge, it's in the lap of the safety valve, NOT a red line on the gauge.
  A final point not in the rules, Flash steam plants?? Just in case yon Wizard wants to attend??
Bunkerbarge
« Reply #41 on: February 23, 2010, 03:28:28 pm »
I'm still not sure what the concern is Ian.  I fully agree that the plant is in the hands of the safety valve when it is on the water, this is precisely why we put so much attention into testing it's functionality before allowing it to steam.  One of the the main parts of the "Steam Test" is to ensure that the safety valve prevents the pressure from rising more than 10% when the boiler is under full flame.  Obviously the pressure gauge helps us to determine that this is in fact the case but it's function is secondary to the safety valve.
Maybe if you tell us what plant you have, what the model is etc. and what your concerns are as regards operating it at an event we are holding we may be able to help you sort it out.
As for flash steam plants, as long as they come with appropriate pressure test certificates that can be directly related to the plant in question then I don't see why not.  Obviously home made plants should all be certified but as far as the rules go they contain steam under pressure so the same considerations for releasing that pressure in the event of something going wrong still remain as a requirement.
An interesting aside here is that we now have so much focus and attention on the requirements of running a steam plant that, as long as the regulations are adhered to and common sense is applied, I see it as a safe activity.  If you now think of how many electric powered boats sail around with 12 v, 7ah batteries or even larger, without fuses fitted I consider them to be considerably more of a risk.  When you then take into account some solid state speed controllers that have been known to burst into flames not to mention high speed brushless electric motors capable of propelling very light Chinese manufactureed models completely out of the water it makes you wonder whether there should be a bit more legislation applied to the electric side of the hobby.
I'm not suggesting we should but seeing a Resolve Tug catch fire and more than one speed controllers burn out quite spectacularly it makes you wonder.
HS93 (RIP)
« Reply #42 on: February 23, 2010, 03:38:26 pm »
Add Ni cads going pop and don't mention what people rightly or wrongley say about Li Pol.  steam is still very safe treated correctley
Bunkerbarge
« Reply #43 on: February 25, 2010, 01:29:21 am »
Further to the requirements posted earlier in this thread please note the following:
The Kirklees Model Boat Club Steam Convention will be held on the 23 rd May 2010 at:
Wilton Park, Bradford Road, Batley, West Yorkshire WF17 8JH
From 10.00 am to 4.00 pm
Refreshments will be available c/o the ladies in the Tea Tent and the pond will be open to all comers during this time.
All types of steam models will be welcome either completed or under construction and tables will be available for display purposes for those who do not want to steam thier models.
Models will require certification to be allowed to steam however "Steam Tests" will be available on the day between 10.00am and 12.00am to assist those models below 3 bar-litres to get up and running.
Clubs wishing to attend and reserve table space please contact Mr Stan Reffin
We look forward to seeing you there on the day
Page created in 0.019 seconds with 18 queries.
