Author Topic: what engine  (Read 3327 times)
hdserv
what engine
« on: February 01, 2012, 12:56:07 pm »
I am building a tug canning by mobile marine models and have a PM research oscillating steam engine 1/2 inch bore 3/4 stroke do you think that this steam engine will b e power full enough for this tug i have a 3 1/2 inch boiler from mainsteam
HS93 (RIP)
  • I cannot spell , tough
Re: what engine
« Reply #1 on: February 01, 2012, 01:41:49 pm »
did you tell Mainsteam what engine it was for? because if you did ,they are a good steam company who know what they are doing and so it should be fine, the reason I say this is that the way the boiler is  fired makes a difference in the amount of steam it produces.,. what sized canning is it ?
Peter
hdserv
Re: what engine
« Reply #2 on: February 01, 2012, 02:02:00 pm »
sorry the pm research engine is a twin cylinder
hdserv
Re: what engine
« Reply #3 on: February 01, 2012, 02:07:43 pm »
the canning 40 inches long by 11 inches yes I did speak to main steam
kiwimodeller
Re: what engine
« Reply #4 on: February 02, 2012, 08:48:33 am »
The P M Engine will push that hull along very well. I have fitted the V twin in to hulls up to 48" long with no problems. I would suggest you use a good big prop so the engine does not rev to much, then it will not use too much steam and the boiler will easily keep up with demand. We have a 75mm x 75mm four blade prop under a 44" steam yacht tender with one of these engines and it could do with a bigger prop still. The Prop Shop does steam props which have more pitch than the diameter and one of those would be ideal. Set the safety valve at 45psi as oscillators tend to leak steam if you have too much pressure. I am sure you will be pleased with the performance and they are very controllable too. Best of luck, Ian.
HS93 (RIP)
Re: what engine
« Reply #5 on: February 02, 2012, 07:16:21 pm »
I would agree with kiwimodeller , don't try to push to much steam through it , and 40" will be no problem at all mainsteam are a good supplier of steam parts so as you have told them you will have no problems looking forward to hear about your build , there are a lot of steam people on Mayhem who will be glad to help if you need any.
Peter
Re: what engine
« Reply #6 on: February 03, 2012, 01:53:45 am »
Well I know nothing about steam, but if you don't mind I'll tag along
with the build and maybe I'll learn a thing or twenty.
Somebody (not too far away) got me steam curious  O0
hdserv
Re: what engine
« Reply #7 on: February 04, 2012, 09:19:45 am »
well will keep you up to date on the build to cold to go down that shed at the moment
Page created in 0.017 seconds with 18 queries.
