Author Topic: Graham TRV1A Engine in a Krick Victoria  (Read 2561 times)
rob1962
« on: June 22, 2012, 02:20:53 pm »
Hello anyone running a Graham TRV1A Engine in a Krick Victoria if so any pics on servo installations thanks my Cheddar Puffin must come out. any info or Pics would help thank you.
        Rob
Proud owner Krick Victoria & Krick Borkum.Cheddar Claire/pintail E & B
KNO3
Re: Graham TRV1A Engine in a Krick Victoria
« Reply #1 on: June 24, 2012, 09:39:32 am »
Are you using the same boiler you did for the Cheddar Puffin to power the Graham TVR1A? I'm asking because the Graham has twice the volume of the Puffin, 8cc versus 4 cc. It would need a more powerful boiler as well.
KNO3
« Reply #2 on: June 25, 2012, 09:19:51 am »
In response to your PM question: I haven't really tested the Puffin boiler with the Graham (only ran it once, without load) so I can't really tell if it could perform well in a boat. It was the old style Cheddar Puffin boiler, with return flues.
However, Cheddar boilers are usually quite powerful, so it might be enough even for the Graham. Just keep in mind that the Graham TVR1A has double the volume of the Cheddar Puffin engine, thus consuming more steam.
To get good results you might also need to increase the prop diameter and/or number of blades, so the Graham won't spin too fast and waste steam without getting the power into the water.
rob1962
« Reply #3 on: June 25, 2012, 03:57:15 pm »
return flu not sure what that is how can i tell please explain i built my Cheddar boiler about 10 years ago sorry im kind of a newby to steam thanks.
HS93 (RIP)
  • I cannot spell , tough
« Reply #4 on: June 25, 2012, 04:49:31 pm »
is it the type 11 boiler have you got a picture that was mated with the Gemini as well
Peter
KNO3
« Reply #5 on: June 25, 2012, 09:56:40 pm »
Here you can see what my Cheddar Puffin return flue boiler looks like.
http://www.flickr.com/photos/28865130@N04/sets/72157609148809485/
If yours isn't the same, having just a single centre flue, with the chimney at the opposite end to the burner, then you have the newer style of Cheddar Puffin boiler.
Page created in 0.085 seconds with 22 queries.
