Hi Fellas, Glad to see you are still here.
Approximate steam requirements for engine: .7ci x2(2 sides to fill each revolution) x2(cylinders) x ~1000 rpms=2800 ci of steam
Boiler heated area ~ 100 sq in.
But If I run at 300-400 rpms, with steam throttle just cracked open, the boiler will maintain ~ 55 psi and the engine runs great. Moderate to full throttle will outpace the boiler. This is with the boiler on medium flame. With the gas cracked full open, the boiler will do better to keep up with the engine, but still not fully. Also, icing on the gas can.
So best practice is moderate heat, low rpms, and I get at least 20 min run time .
As far as boiler fill, I have a small vertical pump I might use. Definitely will have a hand pump. No electronics. Just old old school.....
As far a clenching, I was prepared to glue the planks, real nails for detail, if I can find some 1mm real copper nails and washers...or no washers...don't know yet. Found some great square nails and washers, but a hair too big...
Might have to make my own from copper wire...tedious, but relaxing.....maybe....
