Author Topic: Capacitors on Raboesch Bow Thruster  (Read 925 times)
Andrew-Smith
« on: December 21, 2023, 02:01:10 pm »
Hello,
Can I solder capacitors to the two small wires (2 and 8 o’clock in the picture), rather than the canister? The wires are connected electrically to the canister, not sure where they come from.
Many thanks,
Andrew
Andrew-Smith
Re: Capacitors on Raboesch Bow Thruster
« Reply #1 on: December 21, 2023, 02:17:05 pm »
Hopefully this is the picture!
HMS Invisible
  • MICROGYROS.COM
    • Yes, it works!
« Reply #2 on: December 21, 2023, 03:26:47 pm »
Those are likely to be ceramic disc capacitors from each brush to case, mounted inside.
What you really need is one ceramic disc capacitor across the brush terminals.
Andrew-Smith
« Reply #3 on: December 22, 2023, 07:47:07 am »
That makes sense. There is no mention of it in the instructions. Makes it easy, I always make a mess soldering onto the canister.
Many thanks,
Andrew
Page created in 0.08 seconds with 24 queries.
