The Shipyard ( Dry Dock ): Builds & Questions => Steam => Topic started by: kiwimodeller on May 09, 2010, 11:20:44 am
Greetings all, has anybody experience with using an electric motor to restart a steam engine? I have seen it done but did not take much notice at the time. I have a Gage VR1A single cylinder 1/2" bore by 5?8" stroke. It is reversable but of course may not restart if it stops at top or bottom centre. I have a spare radio channel and room to fit a small electric motor which I thought I would connect to the flywheel with an O ring. Can anybody suggest how big a motor I might need and what reduction ratio? Thanks, Ian.
Just a thought Ian.........how about a flywheel with serrations on the VR1A engine & a servo to joggle the serrations until a steam start is made .... :o - Derek
Leave it permanently belt drive connected and use it as a generator to keep the battery re-charged?
As for size and torque it would be in the try it and see category if the belt drive went to the large diameter on the flywheel and you used a small pulley on the motor you may get away with a pretty small motor
July/August 1986 "Radio Control Boat Modeller" A Barring engine for a Stuart 10V
And not sure if "Bogstandard" showed in effect a tumbler type mechanism for starting on this forum.
Regards Ian.
In can't find any posts from Bogs on this forum but he's around as he pointed me to this forum yesterday. If you want I can PM him on the other forum?
No problem, at the moment I am proceeding in fits and starts with the installation (see my other post) and then when it is up and running I will work on the electric start if it is needed. I have put a reversable prop in the boat instead of using the engine reverse so I may not need the starter but it would be an interesting thing to do anyway. Cheers, Ian.
