Hi Roberto to . The F14 has 8 channels yes and no.
Ok the hand set has 4ch on you can plug other input switches in to the spare expansion channel slots 5 to 8. The input modules can be bought or made. Be seated when you look at the price. You do have the option of using a spare channel putting a 8 way switch encoder and then you would all so need an 8 way decoder.be very seated when you look at the price of these. So a fully loaded F14 can control 22 independent servos at a cost .
The receiver is just an 8ch receiver.
There is another way to control extra channels. This is what I an thinking of using on Celestine when I wire her up.
take you ferry and split the functions in to 2 list.
L1 motors,rudder,bow thruster,stabilizers. that 5 functions. use a normal 6ch raido.
L2 anchor door lights horn etc. Most of the functions will only ever be used near the shore of you could use an 8ch switcher board see link.
http://www.quasarelectronics.com/ctl020.htmhttp://www.modelboatmayhem.co.uk/forum/index.php?topic=18065.msg176182#msg176182As for the twin sticks. What you need to start with is the F14 NAVY this give you twin sticks on the left this set is more expensive that a regular F14. Then you will need to get a new twin stick unit very expensive and fit this on the right at 90 degress ,I am not sure if it will mount like this an email to robbe will confirm this
