Author Topic: Lesro Magnum  (Read 19764 times)
das boot
Lesro Magnum
« on: October 03, 2009, 09:13:02 am »
What's in the box?
A very full box of bits...hull/deck/hatch mouldings in very good quality styrene, already trimmed and ready to fit together. A bag containing rx aerial tube, propshaft and prop, a bag containing all the internal mouldings for the servos, battery boxes, rudder linkages and ball joints, nice brass rudder and tube, a tube of styrene adhesive and a bag of instruction sheets and decals. There's even a moulded boat stand included in the kit.
IMHO...although there's no motor included, the kit is very good value for money. Sandra at Lesro looked after me very well, I received constant communications as my order was being processed, and Lesro gave me a very good deal.
ronkh
Re: Lesro Magnum
« Reply #1 on: October 03, 2009, 09:50:35 am »
Rich,
Just do not ask for advice as to what might be the best motor!!! {-) %%
http://www.aeromicro.com/Catalog/axi__5330_double__outrunner_brushless_custom_double_motor_axi5330double_5398643.htm
They might start all over again and you will very possibly have that attack!!! <:(
Ron.
das boot
Re: Lesro Magnum
« Reply #2 on: October 03, 2009, 10:02:06 am »
Morning Ron,
Once bitten, twice shy mate!  ok2
I have a Tamiya 540 motor coming for the boat, and an eight cell nicad pack is on order as well. I'll try it with that, and then see about changing the motor later if I feel the need....
Flexi drives? Brushless motors? Water cooled thingies?  <*< <*< >>:-( <*< <*<
ronkh
Re: Lesro Magnum
« Reply #3 on: October 03, 2009, 12:49:07 pm »
Well done mate!!
ron.
Re: Lesro Magnum
« Reply #4 on: October 03, 2009, 01:40:50 pm »
Well everything certainly use usable, nice to see a strong (Huco) coupling in there too.
Micro switch motor control?!!? ....  Haven't seen that for a few years.
( I'd round off the lower corners of the rudder for safety reasons! )
Nice brushless in there would be good.... I wonder if something like this would suffice?
http://cgi.ebay.co.uk/RC-1-18-Car-12T-brushless-motor-18A-Esc-3in1-Combo_W0QQitemZ360189676235QQcmdZViewItemQQptZUK_ToysGames_RadioControlled_JN?hash=item53dcfa4acb&_trksid=p3286.c0.m14
das boot
Re: Lesro Magnum
« Reply #5 on: October 03, 2009, 03:58:06 pm »
Aaaaaaaaaaaargh!!!! Somebody shoot him!!!
Or me!!!
das boot
Re: Lesro Magnum
« Reply #6 on: October 03, 2009, 04:05:32 pm »
Back to sanity(Martin...go away!!!) <*<
Made a start on the dry fit of a few bits, Tamiya motor, rudder and arm, radio switch, rudder servo and rx in temporary positions just to make sure things fit ok.
So far, so good...
das boot
Re: Lesro Magnum
« Reply #7 on: October 04, 2009, 05:09:24 pm »
Done a bit more today(inbetween watching the MotoGP and the F1(boring)...got the water cooling inlet/outlet pipes installed and changed the rudder linkage.
das boot
Re: Lesro Magnum
« Reply #8 on: October 06, 2009, 05:50:58 pm »
Tuesday PM update...
The top and bottom hull sections are now glued up. Instead of using plastic solvent, I used silicone sealant to give me a certain amount of flexibility when joining the two halves and also to give me an easier ride. I also added some pieces of closed cell foam, siliconed into place up in the bows for bouyancy...just in case. At the same time I siliconed the prop shaft and rudder tube/water cooling inlet pipe into position.
The flat now stinks of vinegar.... >:-o
das boot
Re: Lesro Magnum
« Reply #9 on: October 08, 2009, 05:36:00 pm »
Another pic of the build so far..watercooling plumbing in place, rudder servo installed, now waiting on the new radio to turn up. Next job is buy the battery packs...
Subculture
    • Dive-in to Model submarines
Re: Lesro Magnum
« Reply #10 on: October 08, 2009, 08:31:47 pm »
What's that horrible lump of dead weight at the stern, starboard?
das boot
Re: Lesro Magnum
« Reply #11 on: October 08, 2009, 08:37:46 pm »
Ballast...
andyn
Re: Lesro Magnum
« Reply #12 on: October 09, 2009, 12:41:08 am »
Ballast needs to be on the left side if you need any at all Rich...
Subculture
Re: Lesro Magnum
« Reply #13 on: October 09, 2009, 09:38:28 am »
Use the BEC on the ESC, it will be fine on the voltage you're running, and with only one servo to pull round.
nick_75au
Re: Lesro Magnum
« Reply #14 on: October 09, 2009, 10:36:35 am »
Wonder where the bec is on the microswitch speed control? :P
Nick
HS93 (RIP)
  • I cannot spell , tough
Re: Lesro Magnum
« Reply #15 on: October 09, 2009, 11:29:14 am »
He is using one with an electric fir built in keep the lake warm , it saves you standing around all day sailing as they waste most of the power heating up..but a bec on flea bay no weight and about £5
http://www.r2hobbies.com/proddetail.php?prod=rcps81706_ub
Peter
Subculture
Re: Lesro Magnum
« Reply #16 on: October 09, 2009, 01:06:35 pm »
AFAIK, Richard is using an ESC, not a microswitch. You'd have to be mad to use the latter on a fast electric these days surely?
A linear regulator is not going to get very hot dropping a couple of volts and powering one servo. Switchmode BEC's are great, especially for submarines or a boat running a high voltage (over 12 volts), but I see no benefit in forking out for another gadget when you have an adequate device built in already.
HS93 (RIP)
Re: Lesro Magnum
« Reply #17 on: October 09, 2009, 01:17:26 pm »
My heat comments where about resistor speed controllers not bec's as I thought that was what he had.
peter
das boot
Re: Lesro Magnum
« Reply #18 on: October 09, 2009, 06:00:30 pm »
I'm building this more or less from the box chaps, I have added water cooling admittedly, but that's about the only deviation from the kit plans. I'm not getting into circuit racing with it, so the instructions say battery pack on the right, so that's where I've put it.
As for bec's and such stuff...no thanks, far too technical for me and this boat.
Ta
Re: Lesro Magnum
« Reply #19 on: October 09, 2009, 06:13:00 pm »
 ... room in there for a small dilithium crystal pack Rich?
das boot
Re: Lesro Magnum
« Reply #20 on: October 09, 2009, 06:47:51 pm »
A what? What on earth is a 'small dilth dithl dlit...one of them?    {:-{
Subculture
Re: Lesro Magnum
« Reply #21 on: October 09, 2009, 07:04:34 pm »
It's what they sue for a warp drive in Star Trek, Richard. Martin is pulling your leg.
Nothing technical about BEC's I assure you, just plug and play. It can't get any simpler, and you only have the one battery pack to worry about.
das boot
Re: Lesro Magnum
« Reply #22 on: October 09, 2009, 07:16:20 pm »
I knew that... :D
In the sub Andy....yes, but not in this little fella. This purely for fun after work, just until the Dragonfish is ready for operational duty.
Re: Lesro Magnum
« Reply #23 on: November 06, 2009, 05:30:59 pm »
Has it had an outing yet?
das boot
Re: Lesro Magnum
« Reply #24 on: November 06, 2009, 06:39:42 pm »
Still sits on the top of the wardrobe Martin...I got carried away with building Deep Quest. I'll finish it one day...
Page created in 0.099 seconds with 23 queries.
