Did a duration running test today with full gaz tank and boiler. The lever of the anton coupe gaz V 70 arms nicely at 40 psi, took 15 minutes to get to 40 psi. I have the impression the gaz regulater V 72 does not really regulate, but give only a very low gaz flow. gives only a 15 to 20 psi pressure on running. After 90 minutes i run out of gaz it only consumed half of the boiler water, i have run the engine for over an hour, but on low speed because i could not get pressure above 20 psi during runs. Limited factor seemed to be the condensor tank as it was ejecting water during running. The V70/V72 are nice pieces of engineering but i have a doubt if they work properly. Any one experience with these? I am going to make a run without these installed but have first to make a bypass gaz line for it. Keep you posted on next duration run.
JJS
