Author Topic: 1/8 scale WWII Higgins Boat Landing Craft  (Read 1495 times)
Doug D
« on: June 01, 2012, 02:10:16 am »
Given the scale of my boat and its overall size I had determined months ago that the propeller diameter that was suggested for the completed boat was simply too small for the size of the craft. I decided to go with a larger 70mm diameter brass propeller and once the boat was put in the water for the first time going with that 70mm propeller was the right choice. I also had to enlarge the rudder up to a matching 70 mm rudder brass on a 3/16" brass shaft. The boat runs beautifully and with that prop and rudder combination it turns beautufully even at wide open speeds. Many said that the motor I chose was too large and too heavy at nearly 2 pounds but so far I am very pleased with everything I have assembled.
The completed boat weighs in at 23 pounds (10 Kg.) but you would never know it once it's in the water.
Page created in 0.081 seconds with 22 queries.
