Pages: [1] 2 3   Go Down
Author Topic: Tamar 1/12 John D Spicer  (Read 78516 times)
SE
« on: March 05, 2014, 03:27:00 pm »
Yet another Speedline Tamar
November 2013 I received a large packet from Adrian Gosling, and somewhat frightened over the prospect of a first time building in perspex I started building in January. I have been impressed by the attention to detail and precision of the perspex, percy and brass parts. Now the electronics and exterior are finished, and I can’t wait till sailing season here in the Copenhagen area begins. I still have time to finish the interior!  It is named “John D. Spicer”, RNLI No. 16-24, stationed at Porthinllaen. It is fitted with two brushless 340 kv running at 12-24 volt. The transom, mast and antennae are manoeuvred by hydraulic. The radar is driven by a 6 mm planetary geared motor. The windscreen wipers are not true to scale, but they work. I want to thank all the enthusiasts at the Model Boat Mayhem for many good advices and hints. I also want to thank Mr. John Falvey for his kind reception at the Barrow Lifeboat station and the many good pictures of the Tamar class “Grace Dixon”.
I place some pictures here from the building and link to a video on Youtube:
http://www.youtube.com/watch?v=JYY0PmnaTKs&feature=youtube_gdata
http://www.youtube.com/watch?v=gtdC9D7QuYc&feature=youtube_gdata
 http://www.youtube.com/watch?v=VTqXEUIBCIE&feature=youtube_gdata
Svend Erik
CJ1
Re: Tamar 1/12 John D Spicer
« Reply #1 on: March 05, 2014, 05:03:25 pm »
That's fantastic workmanship. I'm envious of your mast, ariel, transom door and windscreen wipers; I've never been good with electrics. Lovely to see thank you.
Chris
smudger1309
  • Colwyn Bay M.B.C
« Reply #2 on: March 05, 2014, 08:24:09 pm »
she looks good and another welsh boat  :-))    as mine is 16-25 RNLB Kiwi based at moelfre
RMH
« Reply #3 on: March 05, 2014, 08:26:26 pm »
Nice job and a very quick build especially with all those working bits. Could you possibly share with us how you got it all to work.
SE
« Reply #4 on: March 07, 2014, 01:36:07 pm »
Thank you for all the nice comments, they make my efforts worthwhile :-) !
As mentioned, I used hydaulics for the mast, antenna and transom, below is a picture of the installed hydraulic pump and servos, behind the motors. I am not sure I would choose the hydraulic solution again, mostly because of the messy oil. In order not to disconnect the hydrarulic tubes each time I want to acces to the interior, a cradle for the deckhouse is mounted beside the boat. The deck above the Y-boat is opened by a linear actuator. In the picture below, the motor in the middle turns two threaded rods, of whic one is left, the other right threaded. Thus the actuators goes in opposite directions when te motor is running.Next is a picture showing the simple solution for the windscreen wipers. A small, 3 v motor doing 36 rpm push/pull the bowden cable inside a brasstube. On the cable, at the right spot under the window frame, a rod is soldered, moving the wipers. Finally I can mention, that the top of capstan on the rear deck functions as main-switch, turning a 3-poles rotating switch located beneath deck. :-))
Svend Erik
« Reply #5 on: March 07, 2014, 01:53:56 pm »
Lovely, lovely,lovely.
You have some ingenious solutions to some
frequently mulled over problems.
I think a few members will be copying
your ideas.  %) %) %)
Rottweiler
« Reply #6 on: March 07, 2014, 08:11:21 pm »
Very nice indeed.Well done !
Mick F
« Reply #7 on: March 08, 2014, 12:58:50 am »
SE...as others have stated....brilliant  :-)) ....I have been fortunate to have had my entire working life involved with industrial hydraulics systems for the steel industry, large scale marine & naval applications.....but have never witnessed micro hydraulic fluid systems such as you display
Again like others ...I would be very interested to understand more of the components you have used  O0 .................Derek
david48
« Reply #8 on: March 08, 2014, 07:57:35 am »
Thats a lot good ,I to worked in the heavy plant game as a fitter for amost of my working life and would like to know more about the micro hydraulics never seen this before.
Very well engineered
David
RMH
« Reply #9 on: March 08, 2014, 08:28:23 am »
Excellent stuff. I will have to try to get the wipers working when I eventually get around to building mine. Thanks for sharing this
Flundle (Speedline Models)
« Reply #10 on: March 18, 2014, 04:30:21 pm »
Working hydraulics!
A wonderful model all round.
Can we have a look at the rams?
SE
« Reply #11 on: April 07, 2014, 05:08:38 pm »
Hi Flundle,
some pictures of the hydraulic rams, one of the two for the transom and one for the mast. The arial cylinder is inside the deckhouse. The illuminated screens may be sen through the window, as the interior may be seen through the open door. Also, a picture of the ventilator in the air vent for the motor room.  I had to modify the windscreen wipers to have them look closer to scale. Link: https://www.youtube.com/watch?v=dDjEQk-D8No
Next step is maiden voyage!
Svend Erik
Svend Erik
SE
« Reply #12 on: April 07, 2014, 05:11:06 pm »
And here are the pictures!
Svend Erik
GAZOU
« Reply #13 on: April 07, 2014, 06:08:12 pm »
FAN......TAS.....TIC !
« Reply #14 on: April 07, 2014, 10:06:46 pm »
Well, what can you say?!!
Very well done, a super project. Have a good launch day and don't forget we,d love to see more of this fantastic model.
yachty
« Reply #15 on: April 07, 2014, 11:37:01 pm »
Simply stunning! well done on such a neat job to what is a really nice kit. Keep the pictures coming.
Really interest in the hydrolicks and how much you made and how much was brought and if so who from.
SE
« Reply #16 on: April 14, 2014, 03:36:46 pm »
Hi yachty (and others),
the hydraulic cylinders came from two sources: www.morpower.com and www.wtbcar.com. You can find smaller but then very expensive!
Svend Erik
lankyandy
« Reply #17 on: July 08, 2014, 09:14:00 pm »
just been watching the videos this really is a superb model. excellent work
g6swj
  • Short Wave Jammer! -.-
« Reply #18 on: July 23, 2014, 06:30:35 pm »
Wow -inspired me to build a Severn!
Can you tell me where you got rotating blue flashing light from.
Thanks in advance
Jonathan
SE
« Reply #19 on: July 24, 2014, 09:07:17 am »
Thanks in advance
Jonathan
Hi Jonathan,
The blue flash can be found at www.pistenking.com - expensive, but very good!
Svend Erik
mk1
SE
« Reply #21 on: July 25, 2014, 04:35:18 pm »
Hi try this firm https://astecmodels.co.uk/catalog/product_info.php?cPath=137_140&products_id=1698&osCsid=aee5cc72da38a41fe01
Hi John,
Yes, much cheaper, but very difficult to hide the wires in the mast.
Svend Erik
Svend Erik
g6swj
« Reply #22 on: July 26, 2014, 01:02:59 pm »
Hi Jonathan,
Thank you for info -not sure pisten  king will ship to uk - looks like they only ship to Germany/Austria/Switzerland - did you have to make special arrangements to purchase?
regards
Jonathan
SE
« Reply #23 on: August 05, 2014, 09:36:39 am »
regards
Jonathan
Hi Jonathan,
I had no problems ordering from Germany, there was no special arrangements.
Svend Erik
Svend Erik
ovl
« Reply #24 on: June 24, 2015, 08:26:31 am »
Hello Erik,
Just arrived on the forum, I checked this post and I'm really impressed with your build.
I'm starting a Tamar speedily also, I hope to reach your Level !!!!
Have a great day !!!
Olav
Pages: [1] 2 3   Go Up
Page created in 0.034 seconds with 17 queries.
