Author Topic: "What's in the Box?"  (Read 28858 times)
portside II
  • tugs at rest
Re: Whats In It.
« Reply #25 on: September 16, 2009, 09:40:23 pm »
Brakengarth 1:32 scale
single steerable Kort
90mm 4 blade brass prop
MMM Kort ease shaft
MMM type 8 (discontinued) motor 12v high torque
Electronize fr30 esc
Robbie bow Marx Ludder  thruster fitted with 540 motor -15a esc
fuel pump for bilge pump
two 12v 12ah battery's + 8lb's of lead for ballast
8 ch hitec receiver futaba 2.4ghz
run time not known about 20hrs if you can stay awake that long
very powerful and manoverable tug in the right hands  i will master it one day
link to site  http://www.mobilemarinemodels.com/PDF/Brackengarth.pdf
modified by portside II
Geoff Cropper
Re: "What's in the Box?"
« Reply #26 on: November 26, 2010, 11:53:58 am »
    40" freestyle model tug........Brocklebank
      Now sold.
        Battery..............6v 10amp sealed
        Controller.........Speed King, servo operated
       Motor..............6v Decaperm 2.5-1 geared
    •        Prop........3" 4 blade, L/H standard, brass
       Rudder........Scratch built Becker rudder on standard brass rudder
    Radio.........Futaba M series, 2 channel Tx with 2 liniar servos, and Futaba Rx 27mhz.
Geoff Cropper
« Reply #27 on: November 26, 2010, 12:31:29 pm »
      36" Scratch built US Navy Fleet Tug, ATF 67,  inspired by Glynn Guest model.        Now Sold.
                                 Battery ......... 6v 4amp sealed
                                 Speed controller.......3amp Bob's Board.
                                Motor.........6v  540 type.
    •                                 Prop........40mm dia  3 blade L/H Graupner plastic.
                               Rudder.........Scratch built.
                               Radio.........Futaba M series, 27mhz.
portside II
  • tugs at rest
« Reply #28 on: November 26, 2010, 11:34:56 pm »
one of my latest .
A S.D.M. scratch built hull with two schottle drives ,600 motors
hull ply wood and polystyreen with a pva/paper skin covered with coloured glass resin
http://www.youtube.com/watch?v=modtS8fDpOo
since then i had a little accident with the wheelhouse and had to re build it
daz
Page created in 0.087 seconds with 22 queries.
