Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17   Go Down
Author Topic: Queen Mary  (Read 88379 times)
Re: Queen Mary
« Reply #150 on: February 25, 2017, 08:46:43 pm »
Can you mark the centres before fitting the plates Ken? I plated my destroyer today and marked out the positions and centre marked the portholes before gluing the styrene strips on. I didn't do rivets though!
Re: Queen Mary
« Reply #151 on: February 26, 2017, 10:21:05 am »
Hi Ballastanksian.  There are plans afoot to mark out the positions of the plates as I have several sizes and shapes to contend with, along with different designs of them.  2 rivets and three rivets in lines, which makes it hard on the eyes to work out.  I will be showing this as I go along
Yesterday was one continual punching on them rivets.  I think I'm through the hard graft now and need to get some more Evostick ready for 'sticking on' time..
Below are some pictures of the  production plant used in the process.
Re: Queen Mary
« Reply #152 on: February 26, 2017, 10:27:00 am »
The band saw, set up with protecting sheet of wood cut to blade size.  This saves the half mm plastic being torn downwards and gives a smooth cut which is parallel.  I used to use a Stanley knife but I've only got ten fingers and already had several warnings.   :}
Re: Queen Mary
« Reply #153 on: February 26, 2017, 10:47:23 am »
Here's the punched out pieces.  The plastic strips are fed by hand along the length one at a time to the marks.
One strip produces 160 rivet indents.  Gets boring and achy after 3 hours and then dinner and back for another 2 hours.  30 strips so far.
BFSMP
Re: Queen Mary
« Reply #154 on: February 26, 2017, 12:18:12 pm »
Thanks 'B' ,  it's all interesting stuff. I only need 6000 more rivets  (he says).  I'm certainly going to count them when I've finished.
The portholes will have to be drilled when they are affixed to the hull.
ken
Ken,
neil showed me this little gismo that he made some years ago and sent me the pictures to post you.........made of old clock cogs, a bit of brass and a chisel handle.
Save you a whole heap of time. and every rivet evenly spaced.
Jim.
Re: Queen Mary
« Reply #155 on: February 26, 2017, 12:30:17 pm »
Thanks Jim,
I tried making one years ago and failed when making my Titanic.  I found the results uneven, so abandoned the idea. The tool has the variants of hand movements, so the depth and straightness of the line could not equal the precision of a sturdy fixed machine process.
Looking back, I wished I had made a dual press so that the 'rivets' were always parallel in line.  I don't suppose it will show much at this scale anyway when painted.
ken
Re: Queen Mary
« Reply #156 on: February 26, 2017, 12:58:14 pm »
Hi Ken
 have a look at this build of the Spider j by Gareth Jones and see how he achieved putting the rivet indents in the plastic strips.
http://www.modelboats.co.uk/forums/postings.asp?th=98007&p=10
john
Brian60
Re: Queen Mary
« Reply #157 on: February 26, 2017, 02:56:08 pm »
10 fingers {-) {-) {-) {-) Think you mean 8 fingers and 2 thumbs mate, although in hindsight I think like me, at times you feel like you have all thumbs  %% %% %% %%
Re: Queen Mary
« Reply #158 on: February 26, 2017, 08:34:49 pm »
Thank you for the link John.  I went over and had a read.  I'm glad I've got the job done now as it was a daunting experience.  I had punched 5400 dimples.   %%
Brian ..... stop talking about fingers.  It's still throbbing now it's dried out and crusty.    argh!!!!!.     ok2
I did a count and the rivet total is 5400. That's a lot of punching one at a time.   I had to go out,  so no work on her today.
ken
Re: Queen Mary
« Reply #159 on: March 01, 2017, 10:06:46 am »
Finished riveting .......... are we ever finished with anything ?
The count is now up to 7000+.    O0
I have fitted most of the strips to the hull now by using Evostick, and it's really stuck them down.  I tried removing  a strip after a day and broke the plastic, so I feel confident they will stay there during any voyages.
Here's the latest view from last night and I'm planning to remove the sticky tape today and fit a few doors.
Re: Queen Mary
« Reply #160 on: March 01, 2017, 12:18:27 pm »
They do look rather prominent Ken, how big would they be if you scale them up?
Re: Queen Mary
« Reply #161 on: March 01, 2017, 08:19:33 pm »
They do appear a little large.
Here's a picture of the real ship.  I might flatten mine down a bit, but hoping the paints will reduce the illusion a bit more. I don't plan to put as many as the real ship.   :o
ken
Re: Queen Mary
« Reply #162 on: March 01, 2017, 10:12:24 pm »
Even putting 1/10th of the real number of rivets on the model by any method would be an epic project. You would have to be in real enthusiasm heaven to attempt it.
From a few feet away, they will look the part and then like most models, from fifty feet away they will disappear into the general Queen Maryish shape sailing on the pond. If there was a simpler way of getting a reasonable percentage of the real number on, then I would say go for it.
TailUK
Re: Queen Mary
« Reply #163 on: March 02, 2017, 08:46:01 am »
I've considered just putting the vertical rows of rivet on my QM They appear more prominent than the horizontal rows and would be easier to do.  I've been experimenting with a laser cut tool and an old embossing press.
Re: Queen Mary
« Reply #164 on: March 06, 2017, 10:03:17 am »
I'm still working on  'them rivets'.
I have sanded down the hull  (lightly) to reduce their height and it's come out rather well.
The other problem in the illusion stakes was that the strips were not staggered to give the illusion of plating.  I ended up with a vertical line of joins.  To this end I cut out sections between the joins and fitted new strips to stagger them across the width of the hull.  I think it looks better on the eye now.
I have made the side panels from 1mm plastic for the upper deck which involved a few hundred  windows being drilled and some square ones being filed out.
Re: Queen Mary
« Reply #165 on: March 06, 2017, 09:08:05 pm »
That is an epic window marathon Ken.
Looking good  :-))
Peter Fitness
Re: Queen Mary
« Reply #166 on: March 06, 2017, 09:15:10 pm »
You should now have some sympathy for the riveters who helped to build the real thing, Ken {-)
Peter.
Re: Queen Mary
« Reply #167 on: March 06, 2017, 11:10:21 pm »
I've got SPOTS in front of my eyes.     {-)     {-)
A nice sitting down job without the ear noise, Peter
There are loads of doors as well,  coming through the production line.
ken
carlmt
    • Linkspan Models
Re: Queen Mary
« Reply #168 on: March 07, 2017, 09:28:07 am »
ken
Are they all the same size / appearance Ken?  Take a look at my Norland post......quite happy to bang them out in card on the laser for you if it will save your sanity  :-))
Re: Queen Mary
« Reply #169 on: March 07, 2017, 10:09:42 am »
Thanks for the offer Carl.  There are 20 doors around 10x4 MM, all cut ready for gluing on, so no problem there.  I have to cut inserts into the strip riveting so that they lie flat against the hull in the gaps.  Looks good from a distance, so can't wait to cover the lot in black paint.  I'm hoping to cover the myriad of faults   %)
ken
Re: Queen Mary
« Reply #170 on: March 13, 2017, 03:29:24 pm »
All the rivets and windows have now been produced and we have started gluing the plates onto the hull.
Here is a picture of the doors.  Here's some of the 20 doors.
Re: Queen Mary
« Reply #171 on: March 13, 2017, 03:32:14 pm »
The stern area side plates were drilled and filed for the long windows and more portholes.
Re: Queen Mary
« Reply #172 on: March 13, 2017, 03:34:23 pm »
Took the opportunity of the warm weather and applied another coat of Red Oxide paint.
Re: Queen Mary
« Reply #173 on: March 13, 2017, 03:37:47 pm »
Final piece of the window plating jigsaw was the stern section.  This was glued into place.
I have made a stand from clear plastic to keep the base off the workshop bench and stopping scratching my paintwork.
Re: Queen Mary
« Reply #174 on: March 13, 2017, 08:59:08 pm »
She is becoming an epic build ken! What therapies do you use to get over porthole drilling?
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17   Go Up
Page created in 0.094 seconds with 22 queries.
