Pages: [1] 2 3   Go Down
Author Topic: "Crystal-Voyager" Australian prawn trawler  (Read 8655 times)
B.B
  • B.B
« on: June 22, 2022, 10:37:06 am »
Hi there, the next model under construction of a Gulf Of Carpentaria prawn trawler the "Crystal-Voyager"  83 ft she was built by the Davies Family ,she was built on the banks of the Shoalhaven River near Nowra launched on the 31 st March 1976, towed to Sydney by the "Ajax" then few days later run into while at the wharf by the car carrier "ANL-Australian-Searoader" she then ended up at the Ballina Slipway to have the damage repaired ,started her prawning career the following season in 1977. She was designed by Noel Riley ,her hull is sister ships to previous built trawlers the "Ramia-kathleen" & the "Hazel-Craig". This model comes in at 62 inchs the Keel stem etc is of Redwood and Cedar and the frames are of Beech, ( supplied by Kevin Rasmussen) and her hull sheeting is of 2.7 mm ply , cheers.
Brian  B
steve mahoney
Re: "Crystal-Voyager" Australian prawn trawler
« Reply #1 on: June 24, 2022, 06:01:49 am »
There's some tidy work in those frames already!
B.B
  • B.B
« Reply #2 on: June 24, 2022, 10:39:17 am »
Hi there, thanks Steve,  in these next photo's used a piece of 1 inch thick meranti for the transom, showing her size alongside the "Beninda", and fairing off her frames, Cheers. :-)) ....
Brian  B
« Reply #3 on: June 24, 2022, 01:08:28 pm »
Crikey Brian, she looks enormous. What scale are you building to?
Ray B.
Mark T
« Reply #4 on: June 25, 2022, 04:17:10 pm »
Hi Brian - here we go again for another fantastic build and she's enormous mate  :-))
I love seeing your boats come together with such fine joinery  O0   I also like the way you know the history of the boat too as I think it brings a model to life.
As always I'll be following and good luck - PS I hope you've got a crane  {-)
B.B
  • B.B
« Reply #5 on: June 28, 2022, 10:28:58 am »
Hi guys, This one is the same scale as majority of the others 1:16 scale, and yes its getting heavier by the day so it seems  O0 . Even though the original was a steely , I still like to run a few stringers through for extra strength, I suppose one of the plus's of the larger models is that you have plenty of room inside to work with but the downside is every time you want to turn it around reality sets back in , cheers  :-)) .
Brian  B
B.B
  • B.B
« Reply #6 on: June 29, 2022, 11:10:04 am »
Hi there, in this post showing all her stringers installed and plating her with 2.7 mm ply, cheers  :-)) .
Brian  B
steve mahoney
« Reply #7 on: June 29, 2022, 09:39:18 pm »
2.7mm ply with that framing – it's going to be bulletproof.
« Reply #8 on: June 30, 2022, 07:26:18 pm »
Beautiful framing  :-)
« Reply #9 on: July 01, 2022, 09:48:42 am »
It's also going to be a hernia O0
B.B
  • B.B
« Reply #10 on: July 02, 2022, 11:38:11 am »
Hi there, she gained a bit of weight when I lined the inside and then resined  O0 ,plated her except for her bullwark area, pre fitted those for later.Laminated hardwood for her Keel and Stem section,then fitted her shelves and pre fitted extra deck beams, they will be glued into positinwhen finished working on the inside of the hull...cheers  :-))
Brian  B
Dreadnought
« Reply #11 on: July 02, 2022, 03:10:07 pm »
Great Woodwork as always Brian!!  :-)) :-))
Dave:)
« Reply #12 on: July 02, 2022, 03:36:46 pm »
It most certainly is great work - makes me want to try and build something properly for a change!
Mark T
« Reply #13 on: July 02, 2022, 04:11:59 pm »
The way those knees sit below the beams and on the frames is sublime  O0
B.B
  • B.B
« Reply #14 on: July 04, 2022, 03:55:52 am »
Hi Guys, I made the heel on this one removable ( if needed ?)  used a piece of Colonial teak and inserted a section of  1/2 x 1/8 inch brass flat bar, cheers  :-))
Brian  B
ChrisF
  • What's my favourite cake!
« Reply #15 on: July 04, 2022, 10:10:35 am »
I'm not surprised it's beginning to weigh a lot with the amount and size of timbers!
Beautiful work and lovely seeing all those joints etc.
Chris
Building Fairey Marine boats: Faun 17, River Cruiser 23 prototype, Huntress 23 Long Cabin with stern-drive, Fisherman 27, Huntsman 28, Huntsman 31 and Swordsman 33. All scratch built and to a scale of 1:12
B.B
  • B.B
« Reply #16 on: July 05, 2022, 10:42:29 pm »
Hi Guys , thanks Chris, this post photo's of using the Chux wipes again for sealing & strengthening the inside of the hull, after pre fitting each section gave the inside of the hull a coat of resin before placing the pre cut cloths in and coating with resin, once the inside of the hull was finished, she received another 2 coats & also the bildge areas filled with resin, used 3.2 Kg of resin...Cheers.  :-))
Brian  B
B.B
  • B.B
« Reply #17 on: July 08, 2022, 10:27:37 pm »
Hi guy's, just a few photo's in this post, increased the 8mm shaft tube to 12 mm, I had 2 ex steam spouts from worn out coffee machines ( if its brass it go's in the box) the one I used suited the brace ,just had to drill it out to the size of the outer tubing, cheers  :-)) .
Brian  B
RST
« Reply #18 on: July 09, 2022, 06:53:07 am »
I think "chux" must be our equivalent of "J cloths"? They're used all the time with model railways but  less so for boats but yours cut to suit so accurately it adds another dimension of neatness!  Am continued to be amazed at everything out of your workshop. They are all worthy of masterclass builds
B.B
  • B.B
« Reply #19 on: July 10, 2022, 11:29:06 am »
Hi Rich, not sure if they are still called Chux (so many different brands these days)  that's what they were originally,it's just a bad habit of referring to them as that  O0 . Next was the construction of the steerable nozzle, the tapered sections are of  Tassy oak and around the edges are of Rose wood, she originally did have a Becker style rudder attached but (but was later disconnected probably to efficient ) so attached a fixed rudder plate to her, allowing for clearance she should end up with an 88 mm prop,I put an extra block inside the hull so the rudder stock tubing has a solid 67 mm of timber ( it looks like a bad joint but it's just the edge of the block chipped  O0 )  cheers  . :-))
Brian  B
Mark T
« Reply #20 on: July 10, 2022, 03:28:29 pm »
Wow that is stunning work  :-))
Peter Fitness
« Reply #21 on: July 11, 2022, 01:23:18 am »
Rumour has it that Brian's going to use this model as an ice breaker next time our lake freezes over :}  We may have to wait a while, as we are sub-tropical here {-)
Peter.
B.B
  • B.B
« Reply #22 on: July 12, 2022, 10:14:23 am »
Thanks Mark, she is Serone proof Peter  O0 . I,m not sure  exactly from what the motor is out of ? as I was given it by a fellow club member Martin Whitehead, it should have some grunt and nice and heavy as well, the motor beds are from the Colonial Teak, with the larger models I have been putting double couplings on and have had no issues in doing so , the battery box fits snuggly over the frames, cheers,  :-))
Brian  B
B.B
  • B.B
« Reply #23 on: July 15, 2022, 03:38:48 am »
Hi Guys, undercoated the inside of the hull, then sprayed the gloss enamel on x 2 coats, this time I left the front section unpainted  (just to show whats under the paintwork) ,then installed the pre fitted deck beams and extra blocks (all hardwood)  where the back exhaust stacks and bollard post live,cheers,  :-)) .
Brian  B
RST
« Reply #24 on: July 15, 2022, 05:32:13 am »
Wow.  Never seen jovejoy couplings used like that!  I've only used them in industry and needed a DTI to set them up between the TWO shafts (NOT THREE LIKE YOU HAVE!).
Pages: [1] 2 3   Go Up
Page created in 0.106 seconds with 22 queries.
