Author Topic: Edge V 2.10.6 Centurion  (Read 288 times)
Pat-K
« on: February 12, 2025, 10:05:19 am »
I have a Radiomaster TX16S running Edge Open source software version 2.10.6 and am experiencing many problems with it, like images not being seen on the SD card, settings being lost when using in conjuction with Ege Companion.
Radiomaster support seems to be having difficulties diagnosing these problem and finding a cure.
Is anyone else having problems with the latest version of Edge, I assume that if I tried it on a different hardware platform the problems would still exist as it appears to be a software problem ??
Chose the Radiomaster TX16S because of it's multi protocol receiver support.
Would value in hearing any similar problems, rectifications or opinions.
Oh and BTW I have replace the SD card that contains the software in case there was a problem with that but the problems still exist, a colleague with the same transmitter is experiencing the same problems.
Any help would be appreciated.
TIA
Pat
HMS Invisible
  • MICROGYROS.COM
    • Yes, it works!
Re: Edge V 2.10.6 Centurion
« Reply #1 on: February 12, 2025, 12:31:59 pm »
I don't have radio like this, so bear that in mind.
And there is a wealth of YouTube material you have likely seen, but I'm not about to wade through any.
In the past I diagnosed someone's camera problem to be the camera incapable of reading a high capacity card. So nothing was wrong with his SD cards and nothing was wrong with his camera. There was incompatibility because of the card formatting or its enormous capacity.
That mouldy old experience is all I have to mind.
Page created in 0.082 seconds with 22 queries.
