Author Topic: Glue test. Gorilla/Flex/Loctite/JB Weld Youtube.  (Read 16941 times)
FishdockBob
« on: October 06, 2008, 11:35:41 pm »
I am hoping to plate my hull that I have built with plasticard (10 thou of an inch), but am not sure what glue to use, its a wooden planked hull that has had two coats of poly resin applied to it. I was thinking along the lines of evostick or some other kind of contact adheisive. But was hoping some one who has maybe done this kind of work, could advise me. Thankyou.
Bob...
FishdockBob
Re: Glue advice
« Reply #1 on: October 07, 2008, 01:55:46 pm »
The above should read "I am hoping to plate my hull, that I have built with plasticard"  and not that I have built the hull out of plasticard. But that I want to plate a wooden hull that has had 2 coats of resin with plasticard. Phew if only I had put that comma in the right place... {-) :D
Bob...
Re: Glue advice
« Reply #2 on: October 07, 2008, 01:59:09 pm »
Pardon ?  :-\
FishdockBob
Re: Glue advice
« Reply #3 on: October 07, 2008, 02:24:52 pm »
Sorry for the confusion  ;)
FishdockBob
Re: Glue advice
« Reply #4 on: October 07, 2008, 02:25:41 pm »
Just for you DickyD "What glue do I use for sticking plastic to cured  resin ?... O0
Bob...
[/quote]
FishdockBob
Re: Glue advice
« Reply #5 on: October 07, 2008, 02:27:36 pm »
dreadnought72
Re: Glue advice
« Reply #6 on: October 07, 2008, 02:36:01 pm »
Evostick would be fine. Do paint over it all, though!
Andy #1963
Re: Glue advice
« Reply #7 on: October 07, 2008, 03:10:48 pm »
Hi there
When I built the Moray Firth the coaster, I plated the hull, the same way as you - using plasticard - and, I used Superglue to glue the plates the hull - which was the same style of hull as yours - wooden hull (coated with polyester resin).  There must be approx 500 plates on the Moray Firth's hull and none have come off YET  O0   My model has been around for about 8-9 year and despite what Dicky things  :P it has been in the water a lot more times than Dicky has had baths  :P :D :D :D and it has the bluebird battle scars to prove it - ask Riggers what that means  :D O0  (as in operator not watching where the model is going whilst steering and the model tries to climb out of the lake).
Aye
john
bluebird
Re: Glue advice
« Reply #8 on: October 07, 2008, 03:19:10 pm »
Hi there
Aye
john
bluebird
I haven't got a bath, I have a wet room.  ::)
My boat hid itself in a bush alongside the lake whilst I wasn't looking, but fortunately we could hear it as it has a sound system. :embarrassed:
FishdockBob
Re: Glue advice
« Reply #9 on: October 07, 2008, 03:29:27 pm »
Thankyou very much Dreadnought72 for confirming the Evostick route, my thoughts were to glue with Evostick then consolidate everything with another thin coat of resin, then paint on top. Bluebird again thankyou for your advice, unfortunately I get a very severe reaction with CA,s. I have read that a few of the lads on here now use the odorless type CA. I may try this product in the future, and hopefully show no reaction. Thanks again for your time.
Bob..
FishdockBob
Re: Glue advice
« Reply #10 on: October 07, 2008, 03:35:50 pm »
Aye
john
bluebird
Hmmmmmm an amphibious boat eh, An intersting concept.  ;) ;)
Re: Glue advice
« Reply #11 on: October 07, 2008, 03:46:51 pm »
I also get a bad reaction to standard CA. One whiff and it's 3 days severe hayfever symptoms. I can tolerate the odourless stuff but wouldn't want to use it on a large job. Also it doesn't seem to stick quite so well without using an accelerator. In your case Evostick would seem top be the way to go.
FishdockBob
Re: Glue advice
« Reply #12 on: October 07, 2008, 04:11:55 pm »
Its strange isnt it Colin how it dosen,t affect some people. There,s a lad who lives near me who often spends 8-10 hours a day 6-7 days a week building model boats in an unventilated w/shop and has done for the last twenty or so years and the biggest part of his builds are with CA,s and he dosent, or hasent suffered any reaction at all.
I do suffer with an asthma type condition through 15 years or so shotblasting/paint spraying mostley ships hulls/tanks etc, so have to watch what materials I am using.
Re: Glue advice
« Reply #13 on: October 07, 2008, 04:43:31 pm »
Hi there FishDockBob - if you send a pm to this guy here on this Forum - StarLocAdhesives/FiveStar - he specialises in different types of glues/Superglue etc., and he really to me is the best one to give advice about Glues.  O0
The only thing that puts me off using Impact Evostik - apart from the smell - which to me is twice as strong and deadlier than Superglue is, if you make a mistake in positioning your plate, it is one hell of a job to remove the plate and also the glue from underneath.    I know the same can be said with Superglue - but, having said that, I use the gel-superglue, which gives a little time to work and position your plates.
The other thing I use, whilst using Superglue in large quantities -is, I use 2 computer fans connected to a 12 volt battery to draw the fumes away.   I did have a desk fan - still do - but that causes enough trouble than enough - PS I do suffer, like you do, from chest ailments and sometimes when I get a bit lax and say 'oh I will use the Superglue without the fans' - me chest ends up wheezing like a rattly old engine.  :)
aye
john e
bluebird
Guy Bagley
Re: Glue advice
« Reply #14 on: October 07, 2008, 05:05:05 pm »
the other place is
www.adhesivebrokers.co.uk
they offer all types of adhesives, and they also supply some multinational companies- they know their sticky stuff !
friendly advice,  and as said before i have no interest in this business, i am just one very satisifed customer
Re: Glue advice
« Reply #15 on: October 07, 2008, 06:53:24 pm »
Jusrt another thought. I have been using Evo Stik Wet Grab around the house for various jobs and it seems to work really well. Waterproof and doesn't smell either. I reckon it could be quite suitable for glueing plasticard to grp. It's supposed to even set underwater!
http://www.visit4info.com/advert/Evo-Stik-Wet-Grab-Evo-Stik-Product-Range/59729
FishdockBob
Re: Glue advice
« Reply #16 on: October 07, 2008, 08:17:01 pm »
Well I think this is the boyo that I need to be using. Thankyou for that.
Bob..
Re: Glue advice
« Reply #17 on: October 09, 2008, 08:18:32 pm »
CA should do the job fine , but if the vapour is a problem (it shouldnt be) you could use the odourless CA , generaly its best with the odourless to use an activator as it is always slower, although we have the fastest odourless available its still slower than the standard CA, balsa to balsa odourless is no problem, very quick set, but on plastics its slower due to lack of moisture to trigger the cure.
Contact glues would also work fine, but they are harder to get the bits in the right place, our contact sticks instantly, but you can seperate the parts for about 5 minutes so it does give more time than some contact glues, you can also use our contact glue as a general adhesive assembling while wet.
CA vapour should never be a problem if used correctly......in a well ventillated room etc, as you can not become allergic to it......
But it will irritate your mucous membranes (sinuses) untill they are burned, the burning will trigger the bodys response of producing mucous , this blocks your sinuses and then you will get headaches, the same with your chest, eyes etc, too much vapour and it will dry the surface of your eyes, and your lungs, making the body moisten them, making you cough and your eyes water
Just dont get a large dose of vapour in your eyes an there will be no effect, if you get a large dose of fumes, give up with the glue till the next day and all will generaly be fine, it cant build up in your body, but if the surface gets burned/dried by the vapour then it will not go away untill the fumes do, then your body will heal, once healed/symptoms are gone just dont let the fumes build next time and you should be fine.
The odourless can not give any symptoms as it has such a low vapour presure and high molecular weight that the fumes can not enter the air in quantities that could ever cause a problem, but if heated it will still cause problems (soldering iron etc)
Most of the glues with solvents are actualy more toxic, but again used according to manufacturers recomendations they are quite safe
Some glues with no apparent vapour are the most toxic of all, such as moisture cure polyurethanes, they give off odourless isocyanate vapour, that will set in your lumgs, so glues having a smell can be good, at least you can smell them
We have just started selling retail (has been available from ourselves to the adhesives trade for a few years) a waterbased contact glue formulated from polychloroprene (most common brand of polychloroprene is Neoprene) , you use it just like evostick, but it has no solvents ,you can wash it off before it drys, once dry it is 100% waterproof (the main use we supply it for is adhesive for manufacturers of waders and wetsuits)
We now (10 minutes ago) have the waterbased contact on ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=360096470485
Re: Glue advice
« Reply #18 on: October 09, 2008, 08:20:22 pm »
Just dont get a large dose of vapour in your eyes or breath it in an there will be no effect, if you get a large dose of fumes, give up with the glue till the next day and all will generaly be fine, it cant build up in your body, but if the surface gets burned/dried by the vapour then it will not go away untill the fumes do, then your body will heal, once healed/symptoms are gone just dont let the fumes build next time and you should be fine.
Re: Glue advice
« Reply #19 on: October 09, 2008, 10:08:41 pm »
Sorry, but I have to disagree with your comments about CA. As I stated previously, I find that the slightest whiff of the standard version, whether indoors or outdoors triggers a severe allergic reaction which lasts at least three days. And I know I'm not alone. The so called odourless type does in fact have an odour and the effect is much reduced but I can only use it very sparingly.
I'd really love to be able to use CA but it hates me!
Re: Glue advice
« Reply #20 on: October 09, 2008, 11:31:08 pm »
The CA molecule is too large to trigger an allergic reaction according to the world health organisation, they have run many tests on it and they checked doctors reports from reported cases that claimed a reaction and found no case that ever showed any allergic reaction to CA
But....it can make you feel ill, like the flu
Some people are more sensitive to the effects of inhillation of many things, but the only reaction with CA is purely as an irritant to the mucous membranes, burning/drying them, some people are effected more than others often a sensitivity is caused by other things being used or by the conditions the CA is being used in
i get headaches from CA used on balsa , but not from CA with no balsa!
The odourless CA is a completely different chemical to the standard CA and should have no effect whatsoever (if it is the type that is safe on polystyrene foam) , the smell you can get on the odourless CA is not the cyanoacrylate, the smell you can get is usualy perspex powder that is dissolved into CA to thicken it, this should not create a problem either , but is common to both CA adhesives slightly different grades of perspex but both contain perspex
in standard CA the smell is generaly higher from thicker grades of CA , and higher again from the gel CA due to increased surface area and the chemistry of the product, have you tried the thin with no activator
A good tip with CA is before using the CA, put a bowl of hot water (or a humidifyer) near were you are working, the added humidity will make the CA set faster,and it will also make the CA vapour levels less in the air as the CA is being used
Re: Glue advice
« Reply #21 on: October 09, 2008, 11:50:49 pm »
OK, I accept that it may not technically be an allergic reaction but in my case, and others that I know of, the symptoms are those of acute hayfever which lasts for three days which fits in with your comments about irritating the mucous membranes. The only way I can use it is to take the workpiece out into the garden, hold my breath, glue the joint and run like hell! I really wish it was different but i have to accept that the only CA I can readily use is the odourless variety.
On the other hand, I seem to have no problems with epoxy which some people can't use.
We are all different I suppose.
FishdockBob
Re: Glue advice
« Reply #22 on: October 29, 2008, 11:45:16 am »
Well I tried the Evo Stick Wet Grab, but I wasn't satisfied with it really. Although it gives you ample time to position your piece, it takes too much time for the contact element of the glue to "kick in". While this wasn't as much of a problem on the flat parts of the hull, it did cause problems on the more curvier parts of the hull. I changed over to standard Evo Stick to do a comparison, and while you have to be precise, in placing your piece with the standard, the results were far better then the "wet grab" glue.
On the CA irritation debate which seems to have evolved out of this thread, and in my case the irritant so much nasal/sinus, it really does get my chest and the symptoms are really wheezy breathing and the feeling is the same as being "winded" and not been able to catch my breath.
Bob...
Re: Glue advice
« Reply #23 on: December 29, 2018, 03:08:01 pm »
 I'm sure someone posted this video on here recently.... but I can't find it, so...
Taranis
  • Balne Moor MBC
Re: Glue advice
« Reply #24 on: December 30, 2018, 09:59:13 am »
WOW Martin  %%  resurrecting a 10 year old thread  8) 8)
ANDY
Page created in 0.032 seconds with 23 queries.
