Hi, Phillip
I see you are in tasmania - glad you are on board
Why, oh why do most of my replies start off - I don't know the answer/whole answer/question?
Sorry, but here is another "don't know the whole answer", but your question has lots of the right information built in - so lets see what research and arithmetic tell us.
Thanks for the links - they are just what is needed
First the KMB 33mm waterjet - the webpage says the power requirement is about 650watts at 15000 to 20000rpm - so it is not a crazy-revs device. There are several motors quoted as suitable - and I tried to identify these in motocalc
http://www.motocalc.com/data/motor.htmland managed to reasonably identify the Pletts - these are about 800 to 900KV, and the reccommended Johnston 800 is 1200KV
Please don't be guided by the advertised power of your IC engine - go by KMB instead!
a few more revs will probably not harm the mechanics - Germans build solid kit!
The Brusless you have selected is an inrunner, and the highest of the KV versions of its family. Its a huge motor - well over a pound weight and the power is written as over 3KW! (although the discussion suggests that this, too is mythical and would be accompanied by splashing copper)
at 14V this motor would be turning at 32,000 Rpm. Impressive, but possibly more than the water-jet bearings would like
I suggest looking at one of the more modest KV versions of this motor - around the 1500KV level which would give you the revs at 14V
In answer to your other question - the different versions are made for basically the car and aircraft users - we flyers want to direct drive huge efficient props, but sometimes the ground prevents big diameters so we need to swing a smaller prop faster, or work through a gearbox so there is always a need for several different KV motors in every size.
Plane digression - the same motor frame might have to fly a scale DVll with a 30x10 inch prop on direct drive (2200 RPM), a scale reno racing mustang with a 7x7 prop (17500 rpm), a ducted fan at 37,500 rpm, or a heli with 30:1 main gear. Add to that the different voltages to be used and viola! you have a big range of KVs in every motor type Since this is an inrunner - it is not likely that the core length varies (but a close study of the weights would tell you that) - it is more likely that there are several different winds
from the 2300 you mentioned - 2 turns of fence-wire
to the 650KV version 500 turns of maidenhair wire
(In fact the winds are mentioned somewhere in the literature)
OK, so I exaggerate
ESC can be any that will take the current - and follow the revs intended. You will have no need of reverse from the ESC, as this is done with buckets on a water-jet. (There is, BTW a purpose made ESC for water-jets which incorporates the servo movement for bucket reversing in the throttle stick movement)
The one you referred to looks the business, and none should have any trouble at 20 to 25 K revs/min
Best of luck - please keep us posted on progress - with pics!
andrew
