Author Topic: sanwa bec reciever max input voltage  (Read 2189 times)
Ian Robins
« on: June 04, 2009, 07:00:23 pm »
I have a sanwa 27mhz radio set in a marblehead yacht. The reciever is fed from a 4.8 nicad pack and the winch is fed from a 9.6v nicad pack.
Can the reciever be fed from the 9.6v nicad as well as the winch. Ie both on the same supply via a "y" lead.
thanks
ro88o0
Re: sanwa bec reciever max input voltage
« Reply #1 on: June 04, 2009, 07:13:14 pm »
Would not if I was you it will end up frying it
Stav........................But am I right the others will tell you even if I am right that I am wrong
FullLeatherJacket
« Reply #2 on: June 04, 2009, 07:15:27 pm »
Some receivers have a regulator fitted internally. Your radio manual should indicate this. If not - or you've mislaid the manual - then best to run the Rx via a separate BEC from the 9.6v supply.
And Stavros is  right.............  :P
FLJ
Ian Robins
« Reply #3 on: June 04, 2009, 07:19:29 pm »
Hi all,
Thanks, I thought so but it was worth a try.
ro88o0
Page created in 0.09 seconds with 22 queries.
