Author Topic: Identify vertical boiler  (Read 15361 times)
kno3
« on: March 21, 2010, 09:31:47 am »
I have recently bought this boiler and I'm trying to find out who made it.
It's a very nicely detailed item, with quite a complicated fire-tube arrangement inside.
The pressure gauge reads BRUCE ENG, could that be the manufacturer? I've never heard about them.
boatmadman
Re: Identify vertical boiler
« Reply #1 on: March 21, 2010, 09:40:34 am »
Here is a link to Bruce Eng, they are part of pollymodel engineering:
http://www.pollymodelengineering.co.uk/
I think they mainly do boiler and steam fittings/ engines, dont think they do boilers.
kno3
« Reply #2 on: March 21, 2010, 09:58:53 am »
Thanks, but there's no mention of such a boiler there. The search continues...  {:-{
Engineman
  • Full Steam Ahead!
« Reply #3 on: March 21, 2010, 10:35:59 am »
That's a so-called kingdom type boiler manufactured by John Hemmens (or Maxwell Hemmens), not in production at the moment :-).  Really - a very good purchase, rare thing.
kno3
« Reply #4 on: March 21, 2010, 10:55:14 am »
Thanks, I have discovered a sort of serial number on the boiler's bottom: SK-10-93-180
Any clues?
Bernhard
« Reply #5 on: March 21, 2010, 01:01:45 pm »
Hi...I  came to late to bid on this,,,,good you get it,,,,Nice boiler it is,,,,,,,,Made By Maxwell Hemmens ..special made to the Max4..4cylinder engine,,,,,,,,,,,,,,,
Regards Bernhard
kno3
« Reply #6 on: March 21, 2010, 01:45:22 pm »
Thanks Bernhard, then Hemmens it is. Now I'll have to figure out what engine to couple it with...  %)
kno3
« Reply #7 on: March 21, 2010, 07:36:19 pm »
I've cleaned and de-scaled the boiler today.
Does anyone know how to remove that part with 2 holes where the 2 burners go inside the boiler? Doesn't seem to move at all.
I'd like to be able to use another burner too, that's why I'm trying to figure out how to remove it.
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #8 on: March 22, 2010, 06:47:51 pm »
Hi Kno3,
Wonderful boilers in model and full size- just a little point of scale detail- in full size the spun smokebox top is always polished- usually brass- but i guess n this size copper would look ok. Its a matter of personal preference of course but I thought you might want to know.
Greg
kno3
« Reply #9 on: March 22, 2010, 08:11:25 pm »
Hi, which part do you actually mean?
gondolier88
    • Coniston Regatta
« Reply #10 on: March 22, 2010, 08:52:59 pm »
Hi Kno3,
Compare your model to this picture- the Kingdon boiler on SL Ashphodele- the part I mean is the big polished brass top on the smokebox.
Greg
kno3
« Reply #11 on: March 22, 2010, 09:16:20 pm »
Ok, got it now. But I'm not very keen on scraping the nice paint on the boiler...
Besides:
I've written to John Hemmens and he confirmed it's a Hemmens boiler. He says the cap is a press fit, I'll see if I can remove it without scratching the finish.
gondolier88
    • Coniston Regatta
« Reply #12 on: March 22, 2010, 09:38:32 pm »
Yes, I thought it may be late in the day to do remedial work- however you could carefully paint on paint remover with a small brush then wash off with water- just as a sugestion?
Greg
HS93 (RIP)
  • I cannot spell , tough
« Reply #13 on: March 23, 2010, 12:46:23 am »
is this the sort of thing you are talking about, this is a MHB boiler that I was in the middled of re firbing, the top is coverd in brasso but comes up like a mirror, there where a few of these tops floating about a few years ago on ebay i got  a few but it depends on the boiler size you have Dia..
Peter
Bernhard
« Reply #14 on: March 23, 2010, 01:03:35 pm »
Regards Bernhard
kno3
« Reply #15 on: March 23, 2010, 02:51:54 pm »
Very nice, are they yours?
By the way, does anybody know what the arrangement of flues inside is? Couldn't see much in mine, except that it has fire tubes at the top (in the fat part of the boiler), placed in a circle.
gondolier88
    • Coniston Regatta
« Reply #16 on: March 23, 2010, 04:42:59 pm »
Hi Kno3,
In full size- which I know from his work Hemmens lkes to replicate- they are arranged thus- the diagram on the right being how the tubes wre centred instead of the usual criss-cross pattern taken 45deg from the centreline.
Greg
Bernhard
« Reply #17 on: March 23, 2010, 04:53:27 pm »
hi  ,,I have one in my launch
Made by Mike..Macsteam
gondolier88
    • Coniston Regatta
« Reply #18 on: March 23, 2010, 06:05:45 pm »
Hi Bernhard,
Tell me if I'm wrong, but I think that particular one is a single flue as opposed to multi firetubes?
Greg
Bernhard
« Reply #19 on: March 23, 2010, 06:43:07 pm »
yes,,thats true with,,,3 Cross tube in........bot work great.........
kno3
« Reply #20 on: March 23, 2010, 09:48:22 pm »
Hi Kno3,
Greg
Thanks. The inside of the Hemmens Kingdon doesn't look exactly like your drawing, the smoke tubes are arranged in a circle. The fire box seems to be a 90 degree bent large diameter pipe, but I have no idea how it connects to the smoke tubes. I've made a drawing of what I could discover so far:
kno3
« Reply #21 on: April 04, 2010, 10:56:21 pm »
Hi all,
I have a question. What thread do the tiny valves used by Hemmens for the water gauge have?
It can be seen in this picture, it's the one close to the burner:
By the way, I made the first steam test of the boiler today. Seems to work, but the burner makes a terribly annoying howling noise. How do I get rid of that?
Happy Easter!
benjaml1
« Reply #22 on: April 04, 2010, 11:17:32 pm »
Noise is caused by the air flow, may possibly be resonance...
kno3
« Reply #23 on: April 05, 2010, 12:02:07 am »
And what's the cure? It is really loud and annoying...
Bernhard
« Reply #24 on: April 05, 2010, 08:43:34 am »
hi.  Bot .on the lake you cant here it? ;)
Page created in 0.087 seconds with 23 queries.
