Author Topic: Pulleys and belts  (Read 4026 times)
Albion
Pulleys and belts
« on: November 10, 2010, 12:20:07 am »
Looking for a source of small pulleys and belts. I have a dry hull sub with single piston tank, and would like to fit a ballast slider to change my CG as the tank fills, well to fine trim the boat any way.
Power is obviously low, looking for a pinion pulley to go on a 2mm motor shaft, and a larger pulley , say max 40mm, with 4mm threaded shaft.
any suggestions?
sunworksco
boatmadman
Re: Pulleys and belts
« Reply #2 on: November 10, 2010, 07:52:10 am »
gribeauval
« Reply #3 on: November 10, 2010, 09:22:58 am »
Best in the business in my opinion.
               http://www.hpcgears.com/
True Lifeboat Nutter!!
Albion
« Reply #4 on: November 10, 2010, 09:54:25 am »
wow thats fast, many thanks
tonyH
« Reply #5 on: November 10, 2010, 05:06:25 pm »
Totally agree with Gribeauval that HPC are B Good. I'm pretty sure that you'll have to sleeve the 2mm shaft to 3mm.
Wait till they send you their catalogue - it's amazing.
Tony
Page created in 0.022 seconds with 23 queries.
