Pages: 1 2 [3]   Go Down
Author Topic: Big Box  (Read 18494 times)
trevor v
Re: Big Box
« Reply #50 on: May 08, 2011, 09:55:33 pm »
1st time in water satday OK :-))air test one very minor leak,but it will need a lot of lead did a bit of detale today
Mankster
  • Wheelerdealer
    • RC Model Submarines
Re: Big Box
« Reply #51 on: May 08, 2011, 10:33:02 pm »
At this rate you will have 2 new boats ready for St Albans. :-)
I am working on a similar scaled sub and am considering fitting real wood decking. Are yours individual strips or a sheet that has beed scribed?
trevor v
Re: Big Box
« Reply #52 on: May 09, 2011, 07:20:19 am »
Hi mankster it is real wood deep scribed you can cut into individual strips if you want to.
Mankster
  • Wheelerdealer
Re: Big Box
« Reply #53 on: May 09, 2011, 09:56:41 am »
Thanks Trevor, I have been able to track down any pre scribed wood sheet yet. Gluing individual strips 1mm wide sound a bit of a pain! Another alternative is plasticard that already comes scribed to represent wooden decking but its not as nice as the real thing.
Subculture
    • Dive-in to Model submarines
Re: Big Box
« Reply #54 on: May 09, 2011, 10:21:11 am »
Water jet cutter?
Another idea- the wood grain laminate that you get on office furniture.
Mankster
  • Wheelerdealer
Re: Big Box
« Reply #55 on: May 09, 2011, 11:53:18 am »
You mean using water a water jet on a flat sheet to represent individual planks? Do you you know some where that will do a small job like thing for reasonable cost?
Subculture
Re: Big Box
« Reply #56 on: May 09, 2011, 12:59:45 pm »
Have a chat with Andy Nightingale. :-))
Another option is to make a master from balsa strips, then cast a rubber mould then mould a complete deck in PU resin. You can add fillers to the PU resin which make it look exactly like wood, but it will be totally waterproof and tough as old boots.
nelsona
Re: Big Box
« Reply #57 on: May 09, 2011, 07:53:28 pm »
Interesting and interested, what is and where can you obtain "p-u resin"??
Subculture
Re: Big Box
« Reply #58 on: May 09, 2011, 08:07:29 pm »
PU is short for polyurethane resin. It usually comes in white or tan color (although it is usually translucent until it sets), but you can also pigment it to any colour you like. You can get lots of different types of this resin with different properties (hard, soft, rubbery etc.). The rudder and hydrovanes shown In Trevors build are cast from PU resin.
Good UK suppliers are Alec Tiranti (google them), and if you can find a stockist Smooth-on do an extensive range range of this type of resin.
nelsona
Re: Big Box
« Reply #59 on: May 09, 2011, 08:40:24 pm »
thanks Subculture will follow up the info, I have a Type 7 hukk from Darnell and the deck leaves something to be desired as far as detail is concerned, thinking I would do a wooden decking (with balsa) and "stiffen" this, but open to other options!
Pages: 1 2 [3]   Go Up
Page created in 0.017 seconds with 18 queries.
