Author Topic: Am I wrong ? recever pins  (Read 6425 times)
Re: Am I wrong ? recever pins
« Reply #25 on: April 23, 2007, 03:45:48 pm »
The Robbe F14 can be expanded to 12 functions with a reciever made by them too!
It only costs a SMALL fortune.
catengineman
« Reply #26 on: April 23, 2007, 05:20:28 pm »
Transmitter is not a problem FX 18 which has at the moment 10 channels in use if I want.
Richard,
OMK
« Reply #27 on: April 24, 2007, 12:36:20 am »
So you finally got there. Seems congratulations are in order.
Regarding your 10-ch receiver request, it's reasonably straight-forward to convert most any Rx. A simple decade counter will give you up to nine channels (the 10th being used for the sync pulses).
Have you considered getting your duff Rx fixed and having it converted to a 9-channel job?
catengineman
« Reply #28 on: April 24, 2007, 02:40:43 pm »
Hi, PMK,
 You make it all seem so simple? but for a daft tw#t like me things that use pulses and milli amps are out of my brain power range.
repair a unit with surface mounted doobry's now that would be worth looking on as it were performed, but I am a sceptic and no doubt the cost of repair + decade counter = more than  spanner will let me have.
until such funds are amassed I will have to stay close to tug and vise versa
Richard,
OMK
« Reply #29 on: April 26, 2007, 07:22:18 pm »
Not necessarily. The counter chip cost less than a quid. The whole caboodle could be slung together for less than a fiver.
What do you intend for your duff Rx? Will you still use it?
Would you consider selling?
glennb2006
« Reply #30 on: April 26, 2007, 08:25:12 pm »
I am coming in late here, but you may find an improvement in performance to all your control functions if you power your "servo supply bus" at 6 volts instead of five. The servos will take it. So will the receiver for that matter.
Glenn
catengineman
« Reply #31 on: April 26, 2007, 09:22:37 pm »
Hi, glennb2006,
 I am now running the systen on 6volts from a SLA I have installed into the tug.
PMK,
 I will keep the rec as I have yet to start to build a dredger and the rec will come in handy for this on a trial fitting.
Richard,
OMK
« Reply #32 on: April 26, 2007, 11:08:10 pm »
All received.
Good luck.
Page created in 0.125 seconds with 22 queries.
