Author Topic: Spektrum tx  (Read 3197 times)
U-33
  • K-157 Vepr. Akula-11
Spektrum tx
« on: February 08, 2013, 07:57:35 pm »
Right gentlemen, you know all about surface boats and 2.4gHz radios, so I need your expertise. Anybody recommend a good 4 -6 channel tx that's compatible with a Spektrum MR200 rx? One that I can just bind to the rx and that's it..nothing technical. I don't do technical...I just want to switch the radio on and go sailing.
Your assistance would be gratefully received..
A66
Re: Spektrum tx
« Reply #1 on: February 08, 2013, 08:07:53 pm »
Hi Rich would recommend the Spectrum dx6i, should have no problem with that, i use DX8 only because i fly planes aswell both should be dsm2 compatable.
Steve
U-33
Re: Spektrum tx
« Reply #2 on: February 08, 2013, 08:13:22 pm »
Thanks Steve..and that's literally bind it, turn it on and go sailing?
barriew
Re: Spektrum tx
« Reply #3 on: February 08, 2013, 08:24:36 pm »
Rich,
The DX6i is a computer set. The DX5e is a simpler TX. No memories etc, just the normal servo reversers.. I would recommend this as a plug and play set, especially if you don't need the model memories.
Barrie
PS Its also cheaper :-))
U-33
Re: Spektrum tx
« Reply #4 on: February 08, 2013, 08:27:24 pm »
I just need to be able to swap the pistol grip tx that the Volere came with for a stick type tx, Barrie...plus an extra channel to switch the lights and hooter on/off. Maybe the DX5e would be a better bet, then?
barriew
Re: Spektrum tx
« Reply #5 on: February 08, 2013, 08:31:30 pm »
Rich,
I would say so. The DX5e has 5 channels and requires no set-up. I had a DX6i but sold it as I found the programming quite complicated. I suppose you could use it without the memories, but even servo reversing has to be set in the program, not just a switch to throw. Just my opinion, but from what you say I think it would be ideal.
Barrie
U-33
Re: Spektrum tx
« Reply #6 on: February 08, 2013, 08:37:44 pm »
That sounds pretty good to me, Barrie...I feel another good thrashing for my poor flexible friend is due.
Many thanks for the help mate...much appreciated.
Page created in 0.019 seconds with 23 queries.
