[size=78%]So let's see If I understand correctly:[/size]
- in order to know how much water I need in Ballast Tank I have to CALCULATE the Volume of ALL is ABOVE the Water Line ? .
- how about hes weight as a Sub , I mean If weight is, let's say 7,5 KG and the Volume of everything is on above the water line is 0,8KG I need a ballast tank with 8,5KG with those 10-15% ?
1. Yes, you can roughly calculate the volume above water. And that will correspond to the volume your tank must be able to take in + some more maybe 10%.
2.
Ballast and ballast tank is two separate things.
You have your submarine. If it weighs in total
10KG (EVERYTHING), you need
10 Liter of volume
below the surface to keep it afloat.
(If the submarine is
10 Liter and your sub only weighs
5KG, you will need
5KG of
ballast, for example lead.)
If the volume above surface is
1 Liter (an air filled Tower for example), your ballast tank will need to take in
1 Liter of water before the whole submarine is submerged (neutral buoyancy).
If the
0,8KG above waterline equals
0,8 Liter, you will need
0,8 x 1,15 Liter in your ballast tank.
The weight of everything "above water line" is only interesting if you know what the exact density of the material is.
Extreme example:
If you have
0,8KG of styrofoam above water you will need
0,8 x 1,15 x 50 Liter of water in your ballast tank. Because styrofoam roughly is
0,02KG/Liter.
