Author Topic: Magnetic couplers  (Read 3182 times)
Doc
Magnetic couplers
« on: May 19, 2006, 08:54:50 pm »
I've been following a thread about magnetic driveshaft couplers on another forum.  Do any of you use them?  I'd think that no holes in a WTC would be a nice thing, no wet motors either.  But, no idea as to how efficient these things are, slipping etc.
 - 'Doc
petesubman
Re: Magnetic couplers
« Reply #1 on: May 20, 2006, 07:38:13 pm »
Sounds interesting Doc ,any further info? or pics , Pete
Doc
« Reply #2 on: May 21, 2006, 01:00:12 pm »
Pete,
I'd much rather give the forum's address (you would too after trying to understand my trying to explain any of this stuff :)). So, here it is...
http://www.rcgroups.com/forums/forumdisplay.php?f=60
I hope it works...
 - 'Doc
« Reply #3 on: May 21, 2006, 01:26:53 pm »
These do sound very interesting, just wonder what torque they will transmit.
Doc
« Reply #4 on: May 22, 2006, 02:00:36 am »
Bob,
I'm sure it has to do with the size/number/type of magnet used.  Other than that, your guess is better than mine!
 - 'Doc
« Reply #5 on: May 22, 2006, 09:16:11 pm »
And keeps shock loading off the motor so should help to "soften" the current peaks too.
flag-d
« Reply #6 on: May 22, 2006, 10:56:09 pm »
Magnetic coupling is often used on smaller water pumps.  I've recently bought one at work to boost water pressure from 2bar to 12bar, so I guess they can take some 'work'.  Might be real handy to prevent motor/battery over-load if the props foul in weed etc.
Doc
« Reply #7 on: May 23, 2006, 12:50:09 am »
...And after thinking about it a bit, it really shouldn't make much difference in the two magnet 'plates' were not exactly 'square', sort of tilted a bit.  Think I just did away with those @#$ 'U'-joints!
 - 'Doc
Page created in 0.108 seconds with 23 queries.
