I mentioned in the last post about buying two new motors. Stupidly on my part I forgot to also get the motor mounts! So with not a little trouble I managed to get the 54o type mounts out of the hull and made up a new mount in plexiglas which I have a big sheet of. What I am not happy about and the supplier will remain anonymous ( they didn't come from Component Shop) are the universal couplings. While in the UK I ordered loads of stuff from various sources and when it came by the postie it just got packed away for shipping back to Spain.
Now ready to install the motors I find that rather than having two threaded couplings I have one threaded and one plain insert. So now I need to go out and buy a thread tap and open up a 3mm one from my parts box to 5mm
I also ran out of soft solder during the cargo rail build. I bought another reel from the local chinese shop, have you seen solder catch fire
heating the brass tube with a small blowtorch, touch the solder to the tube and whoomph, the solder is alight like a firework sparkler! Seems the flux core doesn't like heat negating its use as solder
So going overboard I had to break out my reel of plumbers solder and use pipe flux and extra heat hence the blackened parts on the brass tubing.
I hope this coming week brings better luck.
