Author Topic: Robbe F14 vs. F16 - What the difference?  (Read 4476 times)
RadioX
  • Channel Mad!
« on: December 09, 2014, 06:55:02 pm »
Would I be right is saying the F16 is basically an F14 with the LCD control panel and associated functionality added?
If not what the main differences?
Thanks in advance
RadioX
Subculture
    • Dive-in to Model submarines
Re: Robbe F14 vs. F16 - What the difference?
« Reply #1 on: December 09, 2014, 06:59:30 pm »
Yes. Inside the boards are totally different, but basically an FC16 is an F14 with a computer bolted on. Which is no bad thing- very flexible rig, although I would seriously look at something like a Taranis unless you need the layout and extra add-ons of the F-series.
Mankster
  • Wheelerdealer
    • RC Model Submarines
« Reply #2 on: December 09, 2014, 08:06:32 pm »
Yes the F-16 really is the one to go for. The computer is a godsend for setting throws and reversing servos and for the model memories.
Mankster
  • Wheelerdealer
« Reply #3 on: December 09, 2014, 08:19:20 pm »
double post
inertia
« Reply #4 on: December 09, 2014, 08:56:10 pm »
F16 also has those two slider-operated channels (alongside the main sticks) as standard. Go for it. I only sold mine because 'Uggett was crying for it.......................... <:(
DM
Time Bandit
« Reply #5 on: December 09, 2014, 09:04:30 pm »
Are we talking about the F16 or the FC16?
The F16 is basically an 8 channel F14 in the case of an FC18. At least the case had the same shape and option places (3 places for switches above the 2 sliding pots).
FC16 (I believe the C stands for "computer") is the programmable 8 channel version with the LCD control panel.
If you can choose, take the FC16!
regards
Tobias
Mankster
  • Wheelerdealer
« Reply #6 on: December 09, 2014, 09:28:32 pm »
Yes, the FC-16. The F16 was only available for short while before being discontinued 15 or more years ago.
KaMeWa
« Reply #7 on: December 10, 2014, 09:38:06 am »
I agree, go for FC16. Adjustments are really necessary in many cases -  especially expo curve adjustments are really handy, when fine-tuning ESCs :) Helps quite a bit with over-sensitve controllers.
chuffy
« Reply #8 on: December 13, 2014, 08:37:07 am »
Will the FC 16 work with the 40Mhz fm receivers (R136F) that I am using with my F 14? I have contacted several retailers who just say they should do, but I'm not buying one on a "should do" as I have quite a few of them.
Paul.
The severity of the itch is inversely proportional to the length of your reach.
Mankster
  • Wheelerdealer
« Reply #9 on: December 13, 2014, 09:28:48 am »
Yes it will.
chuffy
« Reply #10 on: December 13, 2014, 09:29:56 am »
Thanks very much Mankster.
Paul.
Page created in 0.088 seconds with 22 queries.
