Author Topic: Odd question about Ton class Minesweepers!  (Read 4617 times)
TailUK
« on: May 20, 2015, 01:36:52 pm »
I have decided on a Ton class minesweeper as my next build so I'm putting together the research on the boat so I can make a start.  I've got the 4 sheet plan set and some drawing that are to 1/38th scale.  I've also got some builder drawings that Christian sent me when I bought a 1/72 scale hull from him.
The weird thing is that no where on any of those drawings does it show a stern end view of the rudders, props or shafts.
Does anyone on know how far apart the shafts on a Ton Class were?  Any measurement at all, full size, 1/48th scale or 1/72nd scale would be extremely helpful.
Many thanks in advance!
Les Pickstock
nemesis
Re: Odd question about Ton class Minesweepers!
« Reply #1 on: May 20, 2015, 06:44:39 pm »
Hi, I once made some A frames for a Ton class, if I remember the hull had the bosses marked on the hull where they exited.
Nemesis
TailUK
« Reply #2 on: May 20, 2015, 07:07:49 pm »
Nemesis
 Thanks for the response, Nemesis.  Which hull?  I've got Christian's 1/72nd scale hull, no bosses and a 1/38th scale hull which I'm not sure about the pedigree.  Neither of them has bosses on.
Ian K
  • In the workshop, going daft but happy!!
« Reply #3 on: May 20, 2015, 07:41:26 pm »
Hi Les,
This might be of some help.
The only info I have, sorry!
TailUK
« Reply #4 on: May 20, 2015, 07:49:44 pm »
Thanks for the pic, I've not seen that before.  It's actually pretty useful as it shows the auxillary propellers really well.  They were electrically powered to propel the boat at 4 knots virtually silent.  Very useful when dealing with acoustic mines.
The A frames look considerably deeper than they appear on the drawing but that may be an artefact of the photograph.  Thanks anyway!
colin-stevens
« Reply #5 on: November 03, 2015, 06:23:19 pm »
Think John Lambert did a set, sure it had a stern veiw.
grumpy old XXX
« Reply #6 on: November 03, 2015, 07:32:53 pm »
Active rudders were fitted on Minehunters for
accurate slow speed manoeuvring.
Accoustic mines were the job of Minesweepers
deploying acoustic hammers or displacers.
mudway
  • Model Boat Mayhem is Great
« Reply #7 on: November 04, 2015, 12:03:55 am »
This might help. The drawing is from the RAN's model plans for Gull.
rsm
Roger
TailUK
« Reply #9 on: November 04, 2015, 01:45:22 pm »
Thanks for these.  The info I was after has been kindly supplied by Christian of MTB Hulls.  The Gull drawing show the shafts on a "P Bracket" while the above picture of Iveston shows "A" Frames but I pretty sure the dimension between shafts is the same.  Thanks again for posting.
Page created in 0.092 seconds with 22 queries.
