Time for another little update....
Decided to have a rotating radar so, to that end, bought a nice little Graupner geared motor via CMB.
I've wired it up in such a way as to start rotating at the same time as the motors kick in.
The tube I had previously painted was installed through the wheelhouse roof and through into the lower saloon. Next, a narrower tube was run inside the first one and down to the motor spindle - the motor itself is installed under the access hatch with just the spindle protruding. Happy with that so a 4BA washer was soldered to the top and the radar transponder glued on top. While giving it a test run it suddenly dawned on me that the radar would only just clear the handrails and therefore be far too low for a clear view. Oops!
Finally came up with a solution - added a further short length to the bottom of the narrow tube, joined with a piece of tight fitting clear tubing.
Next came the wiring up of the lights - just 5 in total - Port, Stbd, stern x 2 and for'd light atop the wheelhouse. All wiring was terminated and tidied up (a bit).
Finally for now, made a start on the stanchions / handrails.
I used the technique that Mark T used on his Fairmount Alpine, by using masking tape to mark the holes for the stanchions, lifted this and transferred to a piece of ply. My thanks to Mark for that idea.
So, here's a few photo's.....
Pic 1: Showing the outer tube fitted.
Pic 2: The 1st attempt on the radar.
Pic 3: Beginning the wiring up (the radar motor spindle can just be seen protruding through the access hatch)
Pic 4: All wiring completed and tidied up (sort of)
Pic 5: The extended radar and lights confirmed working ok.
Pic 6: .....with the workshop lights extinguished.
Pic 7: Making a start on the wheelhouse roof stanchions / handrails.....the vacant holes are for the lower structure stanchions.
