Aligning Bulkhead for Tube HolesAll eight 9mm bulkheads are now a reasonably close fit to the inner hull profile, with the interfacing pairs glued together as single 18mm units. Next comes aligning the 72mm thick stack of plywood in preparation for drilling three 27mm holes for the reinforcing tubes, right through the stack.
I decided to use 6mm x 30 dowels to maintain the alignment. First clamping the two double thickness ply partitions across the horizontal and vertical planes, then drilling and fitting two positioning dowels.
Then, in succession, carefully aligning the next bulkhead and dowelling that, turning over and doing the same for the opposite end. Finally the fore and aft bulkheads to complete the secured stack. The stack can now be clamped to the workbench for the auger drilling. The dowels can later be removed, and holes filled.
Three days waiting for Parcelforce Express 24 whilst tracking info remained stuck on “out for delivery”.
The 27mm auger finally arrived, looking like a wood burrowing Thunderbirds Mole.
Hopefully the alignment will be as accurate as I can make it for dry fitting the stainless steel tubes. I do however expect to do some fettling of the tube holes, which may take some time. Only when everything fits will I secure the bulkheads into the hull.
I hope this new tool will
augur well for the fitting operation.
Bob K
