There are different types and sizes of thermistors but fundamentally two different types:
1) NTC (Negative temperature coefficient) as they are heated the internal resistance reduces - these are used in many applications but the obvious is a car temperature sender unit. As the engine warms up the temperature increases and it allows a voltage to flow which moves the voltmeter (temperature gauge)on your dashboard.
2) PTC (positive temperature coefficient) these are exactly the opposite as a voltage/current flows through them their resistance increases which in turn produces heat. These can frequently be used to keep coffee warm on a hot plate and are used in industry.
Specifically these are designed to have certain characteristics such they can only reach a certain temperature and are self regulating so can be used as heating units in certain applications.
The advantage is that they are self regulating so don't need any feedback circuits to maintain a constant temperature. PTC's are designed for multiple applications and can have maximum temperature settings from 60 degrees up to 250 or in some cases 400 degrees!
Sizes range from a few mm to 60mm x 25mm x 5mm.
If I may, have a look at another thread for Iron Duke on this site under warships R&D. Start at the end of the thread and work backwards and it shows the development process of this system and how it came about in more detail together with plans and pictures. Iron Duke has now fired well over 5,000 shots and works consistently. I typically get 300 to 350 shots in a session and because its totally no pyrotechnic can be used anywhere.
Below is a link address for some I have on order.
Hope this is of interest
Geoff
https://www.amazon.co.uk/gp/product/B00M85KTO2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
