Author Topic: New build  (Read 2107 times)
manofkent
New build
« on: December 27, 2017, 12:25:04 pm »
I know this has been discussed in the passed but I am just about to embark on building a Mantua Bruma.  My question to you august peeps is to do with motive power.  As I expect you know, the design is for a single motor to drive the 2 props (both RH rotation).  The optional motor/gear kit is, it is agreed, both expensive and noisy.  Before I go to fitting 2 motors, I wondered if one and using tooth belt drive instead of gears may be an option.  Thing is, try as I might, I have not found a supplier for such items on the net.  I would welcome any suggestions/advice before I get stuck into the build.
If I can't fix it, it ain't broke.
Page created in 0.848 seconds with 18 queries.
