Author Topic: 1/24 Fairmile D  (Read 2215 times)
ex docky
1/24 Fairmile D
« on: June 28, 2018, 05:20:15 pm »
I have a Kingston Mouldings 1/24 Fairmile D
Running gear at present is x4graupner 600's driving 35mm 3 bladed props 9.6v. - current draw is very high!
I would like some advice which type of brushless motors/speed controllers and lipo's that will give a good performance driving the original props.
Ex docky
abreese
Re: 1/24 Fairmile D
« Reply #1 on: July 02, 2018, 07:03:25 am »
 % I run a Kingston hull 1:24 d boat on overlander brushless x4 with g siteck running set.
will have to find paperwork (bills) for type of motor as they are a "xxxxx" to get at!
will contact you soon.
alan
abreese
Re: 1/24 Fairmile D
« Reply #2 on: July 02, 2018, 07:37:13 am »
 :-)) quicker to find than I thought. first, all throttles commoned up so all 4 respond to trans signal at same time.
only drawback using this set up is no reverse.
speed cont= 4x overlander  xp2 60a  sbec esc-rtf
motor = 4x  tornado thumper v3 3548/05  900kv.
battery= 2x turnigy 25-35 discharge 2200 mAh li-po  giving 11.1v.
also two low volt alarms on batts.
this gives about twenty mins running time.used to run her on 4x 777 motors on twelve volts,had to take 5 batts for a sail.
contact if you need more info?
cheers alan %% %% %% %% %% %% %%
abreese
Re: 1/24 Fairmile D
« Reply #3 on: July 05, 2018, 07:09:55 am »
silence a little concerning.
alan
ex docky
Re: 1/24 Fairmile D
« Reply #4 on: July 05, 2018, 08:33:22 am »
Hi
Apologies have been away,
I thank you for the info and will be looking at it with due diligence
Ex docky
Page created in 0.087 seconds with 22 queries.
