Pages: 1 ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 ... 101   Go Down
Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 393348 times)
frogman3
Re: BOATMANS HMS TIGER C20 SCRATCHBUILD IN 1/72 SCALE
« Reply #525 on: July 24, 2020, 08:44:29 am »
The tube being fitted over the  wires
frogman3
« Reply #526 on: July 24, 2020, 08:46:47 am »
AN FITTED inside the mast
frogman3
« Reply #527 on: July 24, 2020, 08:49:08 am »
here the cross member fitted into the mast with its supports
frogman3
« Reply #528 on: July 24, 2020, 08:54:19 am »
AN IT all is ok as the red anti collision lights work ok so now i can press on to the hardest part an that fitting the wires to the mini electric plugs as this mast will be able to be just unscrewed an lifted off the hangar for serveic in in the future
Rob47
« Reply #529 on: July 24, 2020, 03:30:16 pm »
looking good Chris, wires for the anti collision run through the supports?
I will finish this model
frogman3
« Reply #530 on: July 24, 2020, 05:27:26 pm »
HI Bob thanks for your nice comments an no the wires go through the brass box section cross member the supports are solid brass AN ive been studying the deck pics up nr the hull jiont an i think i will have to use a bit of moddelers licence an not do the cut out for where the whale boat are fitted as if i cut the hull here it will weaken the hull as its right near the hull jiont so i think i will have to have the boats mounted on either side fitted on the main deck
chris
T888
« Reply #531 on: July 24, 2020, 06:12:09 pm »
Hi Chris,
Tigers come on  :-))
Regards David
frogman3
« Reply #532 on: July 24, 2020, 07:20:06 pm »
Hi Chris,
Tigers come on  :-))
 HI  T888
YEA she is an im really enjoyin doin the mini eletrics an still got loads to do
AN LOVIN your build an lookin forward to more  :-))
chris
Rob47
« Reply #533 on: July 25, 2020, 03:05:48 pm »
Chris
I reckon that as the major cut is on the top deck, you should not have an issue, I guess the bit that is cut down on the hull sides is the issue
frogman3
« Reply #534 on: July 25, 2020, 03:51:09 pm »
Chris
HI Bob yes you are right as on the sides of the hull where the whale boats are on there derricks thats where the main hull spars  strenghener are an i darent cut through them as remember the hull is as thin as paper to save on wheight  so i think id better just mount the boats on the main deck top only way i can see unless i do the cuts an try an strenghten the hull after but it will add wheight an not be strong so the jurys out on that
chris
frogman3
« Reply #535 on: August 08, 2020, 08:11:21 am »
HI  ALL  UPDATE  well I've fitted on the A/C led's an they all work ok as I've lifted it on an off the mounting on the hangar bay to test the electric plugs uptakes  an the led's  are nice an bright as this is what the rear main mast will look like if i go sometimes night sailing
frogman3
« Reply #536 on: August 08, 2020, 08:21:26 am »
HERE the main mast now fitted to the hangar bay an its now taking power right from the hull so the 5 electric plugs that I've have fitted all work ok an its not finished by a long chalk but will finish this over the winter time now I've got the basics built as i now want to get onto an do the front foremast as I've just fitted a bit of masking tape to represent the big radar to get a little idea of if things looks about right an I'm happy with it
frogman3
« Reply #537 on: August 08, 2020, 08:31:41 am »
WELL here goes on the front foremast an fittin on RED 2MM led's for A/C lights an the white running lights but first some shots of the yardarms that ive fitted on the mast an its again not fininshed as more have got to go on but im running out of time here as while warm wheather i want to leave the masts for winter time work an get on sprayin the hulls in their paint  top coates in the garage  if poss but for now back to that fore mast
frogman3
« Reply #538 on: August 08, 2020, 08:34:00 am »
TOP VIEW
frogman3
« Reply #539 on: August 08, 2020, 08:35:40 am »
FRONT VIEW
frogman3
« Reply #540 on: August 08, 2020, 08:37:32 am »
BACK VIEW with the A/C lights on
frogman3
« Reply #541 on: August 08, 2020, 08:40:59 am »
AN again front view all lit up for when i go night sailing an all the lights will be able to be switched on an off by R/C
frogman3
« Reply #542 on: September 10, 2020, 06:26:42 pm »
HI ALL  update time on what I've been doing on the model
an still on them masts but they are near finished now as just the actual radars to make an fit the safety railings on both masts but this will be done over winter time as I'm struggling to finish both parts of the hulls before the cold whether get here an here the masts have extra bits fitted on an painted in their top colours
frogman3
« Reply #543 on: September 10, 2020, 06:29:04 pm »
top view looking down on it
frogman3
« Reply #544 on: September 10, 2020, 06:31:41 pm »
an lit up an i want the lights this bright so i can see which is tiger if there is other models on the pond
frogman3
« Reply #545 on: September 10, 2020, 06:32:50 pm »
rear view shot
frogman3
« Reply #546 on: September 10, 2020, 06:35:08 pm »
Now the rear main mast all painted up with some extra bits on front veiw
frogman3
« Reply #547 on: September 10, 2020, 06:38:19 pm »
An a rear view shot of it an the A/C lights are powered down as they are just running from 6v but should be 12v but i could not be bothered to change the battery as i can see that the A/C lights work ok
frogman3
« Reply #548 on: September 10, 2020, 06:40:55 pm »
An next showing is the lovely brass portholes an I've about 100 to fit an they are fitted with glass in them
frogman3
« Reply #549 on: September 10, 2020, 06:43:21 pm »
AN a close up shot an i think these brass portholes are a work of art an it will be a shame to paint them grey but got to be done
Pages: 1 ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 ... 101   Go Up
Page created in 0.085 seconds with 22 queries.
