Author Topic: dremel chuck  (Read 5416 times)
frogman3
dremel chuck
« on: October 30, 2019, 01:01:24 pm »
HI all has anybody bought a Dremel chuck for their unit as I have an had a bit of trouble with them ?
chris
Taranis
  • Balne Moor MBC
Re: dremel chuck
« Reply #1 on: October 30, 2019, 01:47:09 pm »
Yes
ANDY
barriew
Re: dremel chuck
« Reply #2 on: October 30, 2019, 02:12:02 pm »
Yes - and the adapter to allow it to fit in Proxxon Drill stand! No real problems although I think it may need a clean and oil as the max capacity deems to have reduced. I use to get a 3.2 mm bit in easily, now it requires a bit of force.
Barrie
frogman3
Re: dremel chuck
« Reply #3 on: October 30, 2019, 02:15:09 pm »
HI Andy  when you say yes do you mean that you have had trouble with the chuck ?
chris
Taranis
  • Balne Moor MBC
Re: dremel chuck
« Reply #4 on: October 30, 2019, 02:18:10 pm »
No it’s just more convenient
ANDY
Mark T
Re: dremel chuck
« Reply #5 on: October 30, 2019, 04:33:50 pm »
I bought a cheap version one and for some reason it kept on falling off when I applied pressure to what I was grinding or sanding. I then bought a genuine Dremmel chuck and that has been fine with no problems at all. I do find that they work best on the flexi drive like in Andy's picture but again I don’t know why.
grendel
Re: dremel chuck
« Reply #6 on: October 30, 2019, 04:38:11 pm »
I have replaced all my collet chucks for 3 jaw chucks as it makes life a lot easier just make sure you get the correct thread as I believe there are more than one standard size.
john44
Re: dremel chuck
« Reply #7 on: October 30, 2019, 05:12:35 pm »
Yes I have had a chuck on my dremmil for 2 years in constant use, so much better than
having to change collets.I got mine from B&Q
tsenecal
Re: dremel chuck
« Reply #8 on: October 30, 2019, 06:26:42 pm »
I have owned one for over a decade.  zero issues, it has literally outlived 3 real dremel tools and one non dremel brand tool.
Re: dremel chuck
« Reply #9 on: October 30, 2019, 06:33:28 pm »
I bought a Dremel.... maybe another brand but it was out of balance but didn't realize at first.
Eventually  bought a replacement chuck... totally smooth after that!   >:-o
frogman3
Re: dremel chuck
« Reply #10 on: October 30, 2019, 07:40:58 pm »
Well thanks for your views guys an it looks like I have been just  unlucky then >>:-( <*< see what happens when the nxt one comes as ordered one off ebay
chris
grendel
Re: dremel chuck
« Reply #11 on: October 30, 2019, 07:48:09 pm »
i have even had out of balance collets, so much nicer when you get a balanced chuck
frogman3
Re: dremel chuck
« Reply #12 on: October 30, 2019, 07:58:28 pm »
HI Grendal is yours a Dremel chuck then ?
chris
grendel
Re: dremel chuck
« Reply #13 on: October 30, 2019, 08:24:51 pm »
i think at least one i bought was a dremel but i have got others too
frogman3
Re: dremel chuck
« Reply #14 on: October 30, 2019, 08:58:42 pm »
WELL both mine jammed an they was dremele must have been a bad batch then
chris
Taranis
  • Balne Moor MBC
Re: dremel chuck
« Reply #15 on: October 30, 2019, 09:00:15 pm »
I much prefer my Proxxon  8)
https://youtu.be/FclCj7fuJ64
ANDY
frogman3
Re: dremel chuck
« Reply #16 on: October 30, 2019, 09:31:28 pm »
Cheers Andy for showin me that utube pic im a little bit wiser now  :-))
chris
frogman3
Re: dremel chuck
« Reply #17 on: November 01, 2019, 11:09:12 am »
HI all well my third chuck turned up an the jaws  don't work an also the chuck wont fit my dremmell thread  from the uk here an someone said some have different threads  at the time I ordered these chucks I dint know about that  but now got no.4 & 5 comin from china as they cheapies see what happen to them
chris
grendel
Re: dremel chuck
« Reply #18 on: November 01, 2019, 01:21:30 pm »
I seem to recall having one that didnt fit my particular collection of dremels at the time, worst comes to worse you can fit the chuck then using a round rattail file run the drill over the file, slowly shutting the jaws, this should at least true up the jaws. I had to do this on the chuck of one drill as i was using 0.7mm drill bits and the out of balance was enough to break the drills.
Pete C
  • start small think big
Re: dremel chuck
« Reply #19 on: November 07, 2019, 07:28:05 pm »
Ive gone through two dremmel chucks, The first locked up and the only way to use it was knock it after loosening up, the second just plain dropped apart.. Now on my third and I dont consider me a rough user
frogman3
Re: dremel chuck
« Reply #20 on: November 07, 2019, 09:32:05 pm »
HI Pete these chucks are not very good an im very diappointed in them  >>:-( <*< ive had three now an rubbish I think  ive got two more on the way on a slow boat from china see if they will work ok
chris
frogman3
Re: dremel chuck
« Reply #22 on: November 08, 2019, 10:19:39 am »
This is the type I bought and not been a problem
https://www.ebay.co.uk/itm/Multi-Chuck-Quick-Change-Adapter-Drill-Bit-For-Dremel-Rotary-Accessories-Kit-M7/152567763855?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20131003132420%26meid%3D62647e83e9424d41a0db214c1e804336%26pid%3D100005%26rk%3D2%26rkt%3D12%26mehot%3Dag%26sd%3D263449229438%26itm%3D152567763855%26pmt%3D1%26noa%3D0%26pg%3D2047675&_trksid=p2047675.c100005.m1851
HI Andy thanks for your reply  on this Dremel chuck an you say yours is ok that's good  well id love one but the last 3 I bought the jaws did not work an jammed an the last one the chuck dint fit my Dremel thread so no good again so I don't know what to do ?
chris
Pete C
Re: dremel chuck
« Reply #23 on: November 08, 2019, 10:50:16 am »
chris
Just oredered a couple to see if they are any better than the poor (my opinion) dremmel provided chucks...
Andyn
Re: dremel chuck
« Reply #24 on: November 08, 2019, 01:19:54 pm »
It's odd, at work we have about 15-20 Dremels that are quite a few years old, mainly 8200's, all with the Dremel official drill style chuck on them, no issues at all and these things get ABUSED. Recently we ordered four new 8220's for new starters, along with the chucks to go with them. Two of them would not fit at all, even on existing 8200's. Seems their manufacturing has changed.
Having said that, if you've managed to break one of the old style chucks then I don't know what to tell you...
Page created in 0.112 seconds with 23 queries.
