Author Topic: Frsky antenna replacement  (Read 2067 times)
petesubman
« on: January 24, 2020, 01:03:16 pm »
Hi all, through sheer clumseyes I have snapped the antenna off my tx it's a hinged type it's a futaba tx with a v8ht diy module , which antenna do I need , help , regards Pete
C-3PO
Re: Frsky antenna replacement
« Reply #1 on: January 24, 2020, 03:08:49 pm »
Think it's this one
https://coolcomponents.co.uk/products/antenna-2-4ghz-duck-rp-sma?_pos=2&_sid=048c37889&_ss=r
Is the socket on the end of the cable male?
C-3PO
petesubman
« Reply #2 on: January 25, 2020, 07:45:48 am »
Hi c3p0 , not sure , the antenna mount is into the case with a grey running into it , is a push fit ,going g to have to take a pic,regards Pete
C-3PO
« Reply #3 on: January 25, 2020, 09:29:39 am »
Hi Pete,
I think the brass fitting on the end of the v8ht transmitter module will be an RP SMA Female (oddly the brass fitting with the pin in the centre)
C-3PO
petesubman
« Reply #4 on: January 25, 2020, 06:02:08 pm »
Hi , yes it has the brass fitting which is female , pete
« Reply #5 on: January 26, 2020, 12:10:12 am »
Are these not softish translations gone back to front?....Derek
C-3PO
« Reply #6 on: January 26, 2020, 10:32:26 am »
Hi Derek,
The "'RP' stands for Reverse Polarity - there a 4 permutations of this plug/socket
https://en.wikipedia.org/wiki/SMA_connector
C-3PO
« Reply #7 on: January 26, 2020, 12:40:09 pm »
Thanks for the clarification data [size=0px]C-3PO ..........[/size] :o  .......must be just me :(( , but it appears to defy logic  ...... Derek
Page created in 0.1 seconds with 22 queries.
