Author Topic: stick neutral zone  (Read 1727 times)
Philbyuk
stick neutral zone
« on: May 05, 2020, 11:13:08 pm »
hi there  connected motors, to two esc's 'fusion aquapower'  and onto single channel on receiver ,, they work well , only problem is there is barely any dead zone on the stick, a slightest touch on the stick and the motors start to hum  as in about to turn ,
transmitter is a futaba 14SG model , is there anyway to make a more 'dead zone on the stick in neutral ? if that makes sense
Re: stick neutral zone
« Reply #1 on: May 06, 2020, 08:38:30 am »
In the instruction manual, there is a mention of "throttle trim around page 20, on page 68, in servo setup instructions, "dead band" gets a mention.
i don't have one, so just guessing.
https://www.rc.futaba.co.jp/english/dl_manual/14sg_e.pdf
As with most radios, the instructions are almost purely for flight, so need a lot of translating for boat use.
Deadband is usually a built in design feature of the ESC, which just does what it is told to do by the radio.  Older ESCs used to have a couple of adjustable pots to set range and deadband, that is now designed into the system software which decides what you are going to get.
Page created in 0.035 seconds with 24 queries.
