Author Topic: 1/96 scale aircraft carrier lifts  (Read 3066 times)
bowman
« on: September 02, 2020, 08:39:29 pm »
Hi all,
I need some help if possible please, i want to make one of my flightdeck work as in going up and down, is there anyone who can suggest the best way to do this please. My model is 1/96 scale HMS ILLUSTRIOUS.
Kind regards
Re: 1/96 scale aircraft carrier lifts
« Reply #1 on: September 03, 2020, 07:24:12 pm »
Hi fellow Ian.
Have a look at Rob47's builds of aircraft carriers. He is working on a CVA01 (I think it's that one) that has working elevators. There are probably others in the archives as well.
Following real life methods is always difficult because the components do not scale in weight, so making the system to sloppy or too tight, where it catches and breaks. Also, balancing the deck is a challenge. But, give it a go!
One option I saw was to use meccano or similar chains and sprockets similar to some real life systems. It would need two motors of the same type and perhaps a way of slowing them down to prevent Vertical take off effects!
bowman
« Reply #2 on: September 03, 2020, 08:02:11 pm »
Many thanks for the information . The meccano certainly has possibilities. I will hunt down the rest of the replies around lifts.
Kind regards
Ian  :-))
C-3PO
srcampb
« Reply #4 on: September 04, 2020, 07:05:30 am »
Could use one of these- plugs right into your receiver.
https://www.actuonix.com/L12-R-Linear-Servo-For-Radio-Control-p/l12-r.htm
bowman
« Reply #5 on: September 06, 2020, 02:13:24 pm »
Many thanks for the idea.
Kind regards
Page created in 0.099 seconds with 23 queries.
