Pages: 1 [2] 3 4   Go Down
Author Topic: HMS Glory  (Read 13220 times)
gingyer
Re: HMS Glory
« Reply #25 on: August 09, 2022, 05:50:49 pm »
Glad you liked it Scott,
Trying to locate crew figures but it’s a bit wired there is nothing similar to what they wore
All the figures are ww2 and modern but Siri g the Korean War the equipment etc was a bit
Different
Akira
Re: HMS Glory
« Reply #26 on: August 10, 2022, 12:31:37 pm »
She looks wonderful. I love and have always wanted to build a large carrier. Alas, I was lured astray by the Gun club...he will be stunning with a deckload of aircraft. 1/72 scale...plenty of room for motors in them.
gingyer
Re: HMS Glory
« Reply #27 on: October 31, 2022, 08:54:13 pm »
work is progressing....
a few issues though, the GRP superstructure was all wrong and the combing for it to sit on was worse. so outwith the old and to make my own.....
the old combing was cut away and the hole filled in.
the new opening didn't need to be too big as there was very little going
up into the superstructure.
you can see the difference in height in this picture
I have made the superstructure so that it will be clad in 0.75mm styrene sheet to give it the final finish
I also printed some fittings using my own 3D printer i wanted to see how
they looked in place
Re: HMS Glory
« Reply #28 on: October 31, 2022, 09:27:30 pm »
Super project  :-))
How will you get it to Wicksteed  {:-{
gingyer
Re: HMS Glory
« Reply #29 on: October 31, 2022, 10:48:33 pm »
Thanks Dougal
I think the answer would be carefully  :-))
gingyer
Re: HMS Glory
« Reply #30 on: January 29, 2023, 05:33:43 pm »
The superstructure is progressing...
trying to get the shape done before detailing it all
due to the final hight I am splitting the main mast to help with travel
raflaunches
  • The Penguins are coming!!!
Re: HMS Glory
« Reply #31 on: January 29, 2023, 05:48:50 pm »
Fantastic work once again Colin. I didn’t realise how long the tripod mast was used on RN ships- I thought that by this particular ship it would have switched to a lattice mast but it adds a classical feature on this late war carrier.
On another note, I know you and I were after a mobile crane. Well I found a late 1960s Jumbo but in 1/700 scale! I bought the item from Starling Models thinking it would be something to upscale and wow it’s so small! It measures approx 15mm in the two pieces it comes in. At least I’ve got an idea what it looks like but the minute kit doesn’t help being so small to measure from!
Nick B
Illegitimi non carborundum!
gingyer
Re: HMS Glory
« Reply #32 on: January 29, 2023, 06:32:40 pm »
Yes the tripod mast was still in production until the late 40s I reckon.
It’s the height too from the top deck of the superstructure to the top
Of the mast it’s bigger than the flight deck to the top of the superstructure
I have a small 1/700 kit for Glory it has the crane in it too
I may need to use that as a guide
I also got a couple of 1/72 clarkat tractors and they are small
gingyer
Re: HMS Glory
« Reply #33 on: April 14, 2023, 07:05:16 pm »
Progress has continued on the superstructure, unfortunately work still gets in the way, I am now having to work in the Shetland isles which means I am away for 3weeks at a time   >>:-( >>:-( >>:-(
the latest updates on the superstructure
some of the viewing platforms and bulwarks have been added as well as the forward pompom position
gingyer
Re: HMS Glory
« Reply #34 on: April 14, 2023, 07:05:44 pm »
Some pictures of the superstructure on the hull...
Re: HMS Glory
« Reply #35 on: April 17, 2023, 03:35:27 pm »
I like your club workshop Gingyer! It feels like a model engineer club.
Lovely work on the superstructure and mast, tidy piece.
gingyer
Re: HMS Glory
« Reply #36 on: April 17, 2023, 08:14:18 pm »
Thanks,
the club house we have is fantastic, that's just the seating and build area  ;)
gingyer
Re: HMS Glory
« Reply #37 on: July 09, 2023, 10:22:03 am »
the superstructure is still moving on....
funnel has been made and detailing is on going
the deck is being slowly fixed too, so eventually it will be level and no longer twisting
Klunk
Re: HMS Glory
« Reply #38 on: July 12, 2023, 12:11:35 am »
Must get that book off to you!
full time penguin
gingyer
Re: HMS Glory
« Reply #39 on: July 12, 2023, 09:24:47 am »
Thanks Klunk
Whenever is convenient
gingyer
Re: HMS Glory
« Reply #40 on: October 08, 2023, 06:46:13 pm »
time for an update....
After a lot of work the deck is now fixed and levelled.
the original hatch openings were not sitting correctly and the deck its self was no where near level. I ended up cutting out the new deck openings and filling and smoothing the deck.
today i managed to get some primer applied and the ship seemed to start to come together...
a long way to go yet though
Re: HMS Glory
« Reply #41 on: October 09, 2023, 02:02:12 am »
That's looking very good, she has a well-bodied amidships hull form accentuated by the bilge keels   :-)) ...are the props a pair, or a set?....... Derek
gingyer
Re: HMS Glory
« Reply #42 on: October 09, 2023, 08:20:34 am »
Thanks Derek
The props are a pair of 3 blades props as per the original ship.
This being an original Colossus class, they only had a pair of 3 bladed props
Unlike the later Majestic class which has a 3 and a 4 bladed prop fitted.
Re: HMS Glory
« Reply #43 on: October 09, 2023, 04:31:48 pm »
What an elegant model! She's getting betterer and betterer.
gingyer
Re: HMS Glory
« Reply #44 on: October 09, 2023, 07:17:38 pm »
Thanks Ballastanksian  :-))
bbdave
Re: HMS Glory
« Reply #45 on: October 27, 2023, 07:02:42 am »
Very tidy work gingyer  I think I'll follow along  I'd like to build a large warship one day not as big as this. A 3d printer must be a boon but that's more expense and tech im not on entering into.
Re: HMS Glory
« Reply #46 on: October 27, 2023, 06:09:54 pm »
So mismatched props on a two shaft setup? What was the reasoning behind that?
gingyer
Re: HMS Glory
« Reply #47 on: October 27, 2023, 09:26:51 pm »
Thanks Dave,
There is a lot of untidy bits hidden.
The 3D printer has been great but I am not able to make the files I get that done by someone.
I did think about it but I think the set up I have is ideal for what I want. I can get better quality
Fittings cheaper than elsewhere also I can print as many as I want.
gingyer
Re: HMS Glory
« Reply #48 on: October 27, 2023, 09:29:41 pm »
They increased the power in the engines but the length of the starboard shaft had some significant vibration issues
So they fitted a 4 bladed prop which then allowed for lower revs for the same output.
When I get home I will share a picture of one in dry dock it’s definitely weird.
Re: HMS Glory
« Reply #49 on: October 28, 2023, 02:23:26 am »
I think what Colin was questioning is what I was alluding to, in the earlier images, both shafts appear :o  to have 3 blade right hand rotation propellers
From memory, we saw a model of what appeared to be a Carrier of the same Class at the recent Blackpool Model Show as photographed by Nick B
I'll find the image & post it back here...is has the same/similar hull belly
Pages: 1 [2] 3 4   Go Up
Page created in 0.103 seconds with 22 queries.
