My current project the 1938 Lister pump set is providing challenges.
The Magneto a Lucas RS1 has a top cover cap of Bakelite that has seen better days and the contact screw thread is badly damaged from previous poor attempts to remove the steel screw (bad design)
I appealed for a second hand replacement but that met a stone wall.
So left with no alternative but to have a go at a fix I did!
I cleaned the fixed part up enough to apply solder flux
Then tinned the contact face and a 4 mm brass nut before positioning for soldering together.
With the aid of a chopped down motor coupling I could put a 4mm brass screw in the lathe
To produce a contact screw how it ought to be
Penetrates right thought the HT lead and secures it in place.
Final clean up and all the many cracks in the 84 year old Bakelite were treated to Zap-a-Gap CA
I'm hoping the magneto coil and capacitor are still working
