Author Topic: Prop shafts question  (Read 1136 times)
tassie48
  • bikes birds and burnups
« on: October 15, 2022, 11:29:58 pm »
Hi Crew my new project in 1/24 scale is a PCS ww2 I have a slight problem that I need your help with , the drive shafts outside the hull are 6mm however the props are 4 blade 55 mm  M4 thread the shaft size  is 6mm so do I run a  6mm shaft with a 4 mm thread  for the props at the end , or do I run a 4 mm shaft inside a 6 mm outer sleeve just the outer outside the hull only , with the 4 mm shaft going to a coupler,  motors are going to be T12 from Mobile Model Marine which are a 6 mm drive  shaft low slow reving  trying to keep it prototypical any and all help much appreciated tassie48
john44
Re: Prop shafts question
« Reply #1 on: October 16, 2022, 09:40:32 am »
Hi tassie, I personally would not run 55mm props on a m4 shaft unless it is slow running. I would
get the props re tapped if possible to m5 and the shaft re-threaded to m5
tassie48
« Reply #2 on: October 17, 2022, 07:52:54 am »
John many many thanks didn't even consider that will go with that idea the power and beauty of asking questions on model boat mayhem thank you tassie48
Page created in 0.078 seconds with 24 queries.
