Author Topic: Engel submarine cover seal  (Read 2243 times)
terry1956
« on: April 24, 2023, 12:30:13 pm »
Hi, what’s the best material to use to make a new seal for an Engel submarine. I am talking about the seal for the cover that seals the lower hull. Thanks
Davy1
  • Association of Model Submariners
Re: Engel submarine cover seal
« Reply #1 on: May 02, 2023, 03:30:51 pm »
Flat hatches are not my favourite method but this build log shows the use of O ring "cord", I think:
https://www.theassociationofmodelsubmariners.com/t1845-alexander-engel-russian-typhoon-submarine
David
terry1956
« Reply #2 on: May 02, 2023, 05:03:03 pm »
Hi, I just made one using 3mm aluminium sheet. I also replaced the 3mm rubber cord used with 3mm sponge rubber insulation tape which gives a far better area of water seal
Fred Ellis
« Reply #3 on: May 03, 2023, 02:02:46 pm »
Hi Terry1956
Is it a flat top?
when I first started we used to cover the lid with cling film.  then we covered the top of the WTC with Silicon sealant, the top was then placed onto the sealant and pushed down into the sealant until you had the thickness of the gasket that was required, then you leave it for about a week.
This is best done with all the internals removed.
As I said this is old school and very messy, things have moved on and the way David said is better.
Sub driver
« Reply #4 on: May 04, 2023, 12:09:04 am »
When i did my Akula i bought some 4mm silicon sheet then cut out the hatch and made a 1 piece silicon gasket, you can buy silicon sheet of ebay etc.
Regards.
Page created in 0.098 seconds with 23 queries.
