Author Topic: Glueing wood to steel  (Read 1955 times)
ColinB
  • Bateaux sur la Loire
  • Location: 71110 France, near the Loire and Roanne Canal
« on: September 24, 2023, 01:16:39 pm »
I need a thick epoxy type glue to stick a wooden lever to a rotatable steel peg that needs to take a lot of torque.
Any recommendations regarding the best glue?
JimG
Re: Glueing wood to steel
« Reply #1 on: September 24, 2023, 06:08:58 pm »
For this use it would be best to go for an industrial epoxy glue, a couple of exampleshttps://www.easycomposites.co.uk/rigid-5min-epoxy-adhesive
https://www.motorsandrotors.co/index.php?main_page=product_info&cPath=79&products_id=472
Either of them would probably work but they do have the disadvantage of needing a dispenser which generally uses a mixing tube. Both suppliers will sell the dispenser and mixing tubes. Hysol is commonly used in the construction of turbine powered jets.
Jim
Dundee Model Boat club
ColinB
« Reply #2 on: September 26, 2023, 03:48:49 pm »
Thanks Jim I will try Araldite Extra Strong and see how that goes. There is not much choice were I live.  :-))
Howard
« Reply #3 on: September 28, 2023, 07:54:49 pm »
Ask Stan on here, he sorted me think its called Stixall in a tube or cartage I used it to stick ali-box tube to ply wood great stuff get it from a builders mergents,
          Regards Howard.
ColinB
« Reply #4 on: September 30, 2023, 04:06:55 pm »
Thanks Howard  :-))
Page created in 0.092 seconds with 22 queries.
