Pages: [1] 2 3 4 5   Go Down
Author Topic: my smit nederland build  (Read 45025 times)
MGrob
« on: November 30, 2007, 10:57:40 am »
Hi all, here is the progress of my smit nederland build. Have always wanted a tug and with recent restoration to one of my other boats i thought i'd give building a kit ago.
any help and ideas about the build will be much appreciated, cheers...
all the best
Rob
Re: my smit nederland build
« Reply #1 on: November 30, 2007, 11:44:37 am »
Welcome to the forum and keep up the good work,and DEFINATLY keep posting the build as it goes along
BlazingPenguin
« Reply #2 on: November 30, 2007, 11:55:39 am »
Yer doing well with the wee Smit....keep it up!  O0
One of the very common failings with this model is that people fail to work at filling the grain, time spent there will lift the boat above the chaff.
Sometimes after a period of time the ply deck can sag, I find that fitting some triangles....like the bulwarks, below the deck goes some way to stopping this.
MGrob
« Reply #3 on: November 30, 2007, 12:17:10 pm »
cheers for the advice, and more pics to come soon.
i have heard before that the deck can warp so i already have placed triangler pieces under the deck to help prevent this.
not much more to do until primer, will keep you posted
Re: my Smit Nederland build
« Reply #4 on: November 30, 2007, 12:26:13 pm »
Looking good Rob!  O0
NB. What is that around the hull bows in photoo 3?
Martin
MGrob
« Reply #5 on: November 30, 2007, 12:36:22 pm »
sorry if im gonna sound dumb, but what area of the bow are you looking at? and is there something wrong?
Captain Povey
« Reply #6 on: November 30, 2007, 03:28:09 pm »
Hi Rob, She is looking good and I will follow the build with interest. As I have not built one of these from scratch but only refurbished one a thought comes to mind. I am struggling to find a way of sealing the hatch on mine with out making it too ugly and I am keen to avoid doing a 'Tug Kenny' on the first sailing. I think it might worth considering how to fix and seal the hatch now before you go too far and I am sure there is lots of good advice out there. Cheers Graham.  O0
meechingman
  • Tugs Rule, OK!
    • Andrew Gilbert
Re: my smit nederland build - deck securing
« Reply #7 on: November 30, 2007, 03:57:00 pm »
I'm restoring one at the moment, Captain. I'm off to work in a few minutes (got to do something while yet more paint dries on the deck) but I'll post a pic of how I've done it later tonight.
MGrob
« Reply #8 on: November 30, 2007, 05:35:28 pm »
the hatch on this tug has concerned me, and any ideas would be great.
seems like a bad design but would be great to see how Andy has done his
« Reply #9 on: November 30, 2007, 05:59:02 pm »
Martin
MGrob
« Reply #10 on: November 30, 2007, 06:48:14 pm »
ahhhhh i now see what you were looking at.
theres no problem there, it was the reflection of the water from the pond.
« Reply #11 on: November 30, 2007, 06:50:24 pm »
Martin O0
meechingman
  • Tugs Rule, OK!
    • Andrew Gilbert
« Reply #12 on: November 30, 2007, 07:24:15 pm »
I want to use mine for towing, and obviously the deck would just pull off!  :-\
So I put a wooden 'lip' at the rear of the opening, glued and bolted. The deck slides under this and is held firm. The next step is to add brass turnbuttons port and starboard, just aft of the superstructure. These will turn through 90 degrees in use and clamp the deck in place at that point. I don't think it will move! Finally, I've either got to remove the winch and bollards and replace them with ones that are not just glued in place - or, and this is the preferred option, drill through the deck, very carefully, into the bitts and winch and screw them in place.
Haven't done the turnbuttons yet, but I'll post some pix when I do. The bolt heads in both cases will be covered with black plastic caps.
bobinnit
« Reply #13 on: November 30, 2007, 07:42:32 pm »
Hi Rob, very nice looking boat, will be interesting to see the progress. ;) ;)
BlazingPenguin
« Reply #14 on: November 30, 2007, 07:47:09 pm »
You may find that rigours of towing will pull the stern, or at least the aft quarters clear under water from time to time, my remedy was to seal the hatch with clear 'Freezer Tape'...got mine from a chap who advertises on Ebay in the model boat section from time to time, but I may have his email if required.
MGrob
« Reply #15 on: November 30, 2007, 07:56:58 pm »
cheers for the advice Andy....
has certainly given me some ideas of my own to seal the hatch compartment.
MGrob
« Reply #16 on: December 01, 2007, 11:36:46 am »
hi guys, done some more to the build last night and this morning.
started detailing the bridge and finishing the shaping of the roof
the roof section took some shaping. but finally happy with how its come out.
also made the air vents
and made 1 of the 2 exhaust stacks
will soon be time to put down some primer and give her some colours
Rob  O0
Captain Povey
« Reply #17 on: December 01, 2007, 02:58:09 pm »
Hi Rob and all the other contributors particularly on the hatch sealing. Some good ideas there. Rob while I think about it if you are planning to make radar rotate it would be worth thinking about it now. I did manage to retrofit mine as part of the refurb but it was a bit awkward with the cabins etc all fitted to the deck. Cheers Graham.  O0
bigford
« Reply #18 on: December 01, 2007, 06:08:58 pm »
to all of you wood boat builders LOTS of sanding sealer then body filler
billings wood grain is so hard to cover up. not so bad if your boat is
suppose to be wooden but these are steel tug.
just some advise  O0 the boat is looking great
MGrob
« Reply #19 on: December 02, 2007, 05:24:42 pm »
plenty of sanding sealer at the ready,,  O0
i have also got the radar working now thanks from the advice from Captain Povey  ;)
meechingman
  • Tugs Rule, OK!
    • Andrew Gilbert
« Reply #20 on: December 03, 2007, 03:36:03 pm »
Now here's a puzzler for me that I'm sure someone will know the answer to.
Having now completed all the refitting and repainting of the main deck, bulwarks and fittings, I'm looking at repainting the hull itself. The original owner sure goofed this, starting by not using a primer coat. Then, measuring from main deck level, at the front end of the main freeing port, down to the top of the boot topping and plimsoll line on the starboard side, it's 70mm, but on the port side only 60mm. Can someone tell me what this measurement should be please? is it shown on the plans (which, of course, I don't have!)
banjo
Re:smit nederland Waterline
« Reply #21 on: December 03, 2007, 05:54:33 pm »
Try these:-
meechingman
  • Tugs Rule, OK!
    • Andrew Gilbert
« Reply #22 on: December 03, 2007, 07:50:53 pm »
Thanks Banjo.  O0  I was afraid it would be something like that, so it's going to be a complete strip and repaint. :(
Next question has to be - what's best for stripping enamel, or should I just rub down slightly, prime and then spray?
banjo
« Reply #23 on: December 03, 2007, 08:00:25 pm »
Stavos is the painting expert ...see some of his paint threads...
If it was mine I would use lots of elbow grease, wet and dry lots of soapy water and cut it back till the white showed through.
Then use Plasti-Kote spray undercoat then the MATT SUPER....
I'd avoid high gloss finish at all costs..
but I'm no expert...
 O0
TRY http://www.abcmodelsport.net/p390562/MODELSTRIP.html
Captain Povey
« Reply #24 on: December 03, 2007, 08:04:45 pm »
Hi Andy,  I was going to say that as a guide, with my boat on the table the height to the water line from the bottom, measured at the middle of the length is 95mm but Banjo beat me to it with a more accurate method. I am no expert on painting and there are plenty on here who are and a quick search of the topic will give you loads of info. For my own boat I decided that stripping was not an option. I was afraid that any solvent good enough to remove enamel would probably also melt the hull. I just gave it a good rub down and repainted. It was brushed on as I do not have a spray gun. Cheers Graham.  O0
Pages: [1] 2 3 4 5   Go Up
Page created in 0.026 seconds with 24 queries.
